Author Topic: gti  (Read 1346 times)
Offline bluetiger
gti
« on: 26 December 2012, 15:10 »
hi i have got a 1.8 turbo it is on a x plate so 00/01. its ran fine till now. After I have driven the car for a while the temperature is at about 90 which is normal, when I turn the car off it takes three or four attemts for the car to turn over and re start. When it does turn over it revs itself up and over 4000 rpm.  At this point I have to turn the engine off.  Following this problem I have cleaned the carboretor and put in new spark plugs.  The problem still evident.
AFTER PLUGING IN . IT CAME UP WITH NO CODES.
 :cool: thank you all that tryed to help it was a temp sensor that needed changing for a new one.running sweet now.
« Last Edit: 27 December 2012, 18:52 by bluetiger »
Offline navmk4gti
Re: gti
« Reply #1 on: 26 December 2012, 15:54 »
Try cleaning throttle body. Have you checked for fault codes
Offline Granta Gti
Re: gti
« Reply #2 on: 26 December 2012, 17:09 »
Sounds like a dodgy crank position sensor. Scan it for codes and go from there
Offline Hoggy
  • Mk4 GT TDI 150.
Re: gti
« Reply #3 on: 26 December 2012, 17:18 »
Crank sensor would explain the non start, but strange avout the rev surge. As said above, scan for codes and if you can have a look at the live data to see if your temp sensor is behaving itself, but trouble codes will probably tell you the story.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: gti
« Reply #4 on: 26 December 2012, 17:58 »
carburettor?
Offline Hoggy
  • Mk4 GT TDI 150.
Re: gti
« Reply #5 on: 26 December 2012, 19:10 »
carburettor?
I'm guessing throttle body was meant.. :wink:
Offline bluetiger
Re: gti
« Reply #6 on: 27 December 2012, 10:13 »
after pluging in it there was no codes come up
Offline markallen
  • AUM 1.8 20v Turbo 150bhp for now ;)
Re: gti
« Reply #7 on: 27 December 2012, 11:41 »
I had a problem on my polo 9n sport. Turned out it was the engine temperature sensor. Not sure if golfs have them but someone might know ha ha.
Golf Mk4 GTi Turbo, R32 front bumper, Lowered on ProSport Coilovers, Bora illuminated vents, Armrest, Heko wind deflectors, Aluminium vinyl trim.
Soon to be added, FMIC, 3" exhaust, Remap..oh and new turbo :(
Offline Hoggy
  • Mk4 GT TDI 150.
Re: gti
« Reply #8 on: 27 December 2012, 15:33 »
Ok so no codes. But did you look at the live data like I said to see if the temperature behaved itself?
Just because your gauge says one thing doesn't mean the engine management is reading that.
Offline wotavudunn
Re: gti
« Reply #9 on: 28 December 2012, 16:59 »
