Author Topic: fitting a cone filter to a mk3 16v  (Read 3405 times)
Offline Screech16v
  • MK3 20vt AGU
Re: fitting a cone filter to a mk3 16v
« Reply #10 on: 24 December 2012, 11:15 »
If you get/have the 57i kit then there is a pipe out the back of the filter to connect to the breather plus houses the air sensor,i ran this for a while and it does sound good,only noticed heat soak in heavy traffic/summer time tbh,modded airbox cold air feed and panel filter was to follow but you do lose the noise.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 24 December 2012, 11:54 »
My modified airbox has a pretty decent induction note and thats without drilling or hacking holes in it. Its all about making thr intake opening larger and clearer with a cold air intake attached.
Offline tweed
« Reply #12 on: 24 December 2012, 12:03 »
Yep mines got a 80mm hole and does give a little roar
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #13 on: 25 December 2012, 00:50 »
so do you recon smoothing the inside and making a fat hole for the cold air feed is the way to go? i'm guessing the best place for the feed is the black plastic grilles below the bumper
Offline Screech16v
  • MK3 20vt AGU
« Reply #14 on: 25 December 2012, 11:59 »
Lower grill is good until you come to deep water lol  :wink:
Offline davemk4
« Reply #15 on: 25 December 2012, 12:17 »
Ive just a got the gen k&n kit come complete with brackets and breather filter cant wait to fit it and drive this car lol
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
