Author Topic: Would this replace the pcv?  (Read 2310 times)
Offline Rob Zombie
« on: 22 December 2012, 18:31 »
Would this replace the pcv system?
http://www.awesomegti.com/car/vw/golfmk4/42-draft-vacuum-manifold-kit-cnc-finish
If not, how would you guys go about replacing it?
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline GTi_James
Re: Would this replace the pcv?
« Reply #1 on: 22 December 2012, 18:34 »
...say whaaaa?!
Offline Rob Zombie
« Reply #2 on: 22 December 2012, 18:46 »
Lol that's a no then - has anyone got the part numbers for the original pcv ?
BHP: 231
TRQ: 251.7 lb-ft
Offline navmk4gti
Offline EsSeX dAn
« Reply #4 on: 23 December 2012, 11:43 »
what about doing pcv delete mod?thisll remove the pcv problems and also stop all the oil vapours re entering the tip
i think i love you.....
Offline Rob Zombie
« Reply #5 on: 23 December 2012, 14:08 »
I've been looking into this on the weekend - and it really does look like it could well be what I'm looking for - does removing the Pcv system affect the car atall in any way? I mean will it effect emissions at all? Has anyone carries out the Pcv delete?
BHP: 231
TRQ: 251.7 lb-ft
Offline GTi_James
« Reply #6 on: 23 December 2012, 15:43 »
its not a delete as such, more of a replacement...a better replacement, it prevent oily vapour re-entering the engine and keeps it nice n healthy
Offline Nino
« Reply #7 on: 23 December 2012, 15:59 »
Current - MK6 GTi Edition 35
Offline Rob Zombie
« Reply #8 on: 24 December 2012, 09:25 »
I think i may take a look into changing the pcv system-  it does also seem there's a few options and ways to go.
This is the thread that i found
http://uk-mkivs.net/forums/t/269734.aspx
has anyone else followed this... If so, is the PCV itself removed all together? and are you basically running straght pipe from the block breather up to a T then into the catch can?
I'm just trying t understand if  all the valves are removed... now i jsut need to sorce the T and the 19mm piping!
BHP: 231
TRQ: 251.7 lb-ft
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 24 December 2012, 11:14 »
Yes the PCV valve gets removed; mine is sat in the shed
