Author Topic: Would this replace the pcv?  (Read 2321 times)
Offline Rob Zombie
Re: Would this replace the pcv?
« Reply #10 on: 24 December 2012, 11:27 »
cheers wazzer - seen you did yours a while ago - has it all been wellw orth it in the end? did you follow pat's guide?
Just to clarify mate - does this effect emissions at all if you remove the PCV completely? did you also remove the suction jet pump and run a single vacum? Sorry for all the questiosn on this - jsut trying to figure out what parts i actually need to purchased to complete the full set up?
« Last Edit: 24 December 2012, 11:30 by Rob Zombie »
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline Dalo Harkin
« Reply #11 on: 24 December 2012, 11:30 »
Yes you rip it all out, where the oil filter breather is has a 19mm end
The rocker cover is a 19mm end
and the puck is 19mm
so you decide which 2 to join to a T and the other one straight into the can
Offline JimBR
« Reply #12 on: 24 December 2012, 11:37 »
I replaced all of mine with silicone equivilents from creation motorsport which shouldnt split, they fit well and I used good quality jubilee clips so they shouldnt leak. Surely the PCV valve is there for a reason?
Offline Rob Zombie
« Reply #13 on: 24 December 2012, 12:09 »
yea that's what I'm thinking - im reluctant to remvoe the system but jsut wanan know if there's ANY differences when the PCV valve itself is removed?
BHP: 231
TRQ: 251.7 lb-ft
Offline Rob Zombie
« Reply #14 on: 24 December 2012, 12:12 »
just found a cheeky little palce to get all my 19mm ID pipes ad fittings from
http://www.etektuning.com/42-draft-stealth-oil-catch-can/
I think Im going to use the IE breather adaptor and 19mm threaded fitting here - http://store.42draftdesigns.com/PCV-90-Threaded-Fitting-34-Plastic_p_364.html
BHP: 231
TRQ: 251.7 lb-ft
