Author Topic: g60 1.8 supercharger  (Read 1709 times)
Offline GT3 Turbo
« on: 20 July 2005, 12:17 »
anyone got any idea what the hp is on a standard engine?
Cheers Smokey
Offline *Dubby*
Re: g60 1.8 supercharger
« Reply #1 on: 20 July 2005, 12:40 »
160 bhp on a corrado  :smiley:
Jeeeeeeeeeeeeeeeeeeeeeeeeep
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 20 July 2005, 12:46 »
same on a golf
Offline GT3 Turbo
« Reply #3 on: 20 July 2005, 13:31 »
ok, cheers  :grin:, are they easy to tune up? do ya reackon i could get 200+ out of it relatively easy?
Offline ...joe
« Reply #4 on: 20 July 2005, 19:24 »
with a bit of work yeah. smaller pulley and a chip is normally the first step, then head work then ported charger, but decent air filter and exhaust should be done first.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline GT3 Turbo
« Reply #5 on: 21 July 2005, 10:27 »
argh excellent thats good to hear... cheers m8. do you know if they fit into the mk2 pretty easily? need to find a gearbox for it if im gonna put it in the golf, do the g60's come with better gearboxes than normal 8v ones?
Offline ...joe
« Reply #6 on: 21 July 2005, 22:00 »
i'm pretty sure they all had a cable change gearbox, which is smoother. the g60 is essentially a pb engine digifant with a few tweaks to get it to run a supercharger. so are straightforward to put in. the only thing which might make things tricky is if the engine comes from a corrado the ecu is on the right hand side whereas its on the left on a golf which i think can make the wiring a bit of a nuisance to get installed neatly.
