Author Topic: davemk4 - '01 1.8T  (Read 32948 times)
Offline jv
  • Administrator
davemk4 - '01 1.8T
« on: 21 December 2012, 14:46 »
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline davemk4
Re: davemk4 - '01 1.8T
« Reply #1 on: 21 December 2012, 17:10 »
Thanks full spec etc and piccies to follow over weekend
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline davemk4
« Reply #2 on: 23 December 2012, 12:35 »
right so heres the car. full spec listis
Golf GTI mk4 1.8T
3 door
2001 Y plate
117k with full service history
all coil packs replaced
16'' alloys
sports interior
climate control
piccies will update with some better but she tucked away in garage
interior needs a quick shampoo etc and car is due its cambelt.
soooooooooooooooooooooo  heres a list of whats sat in boxes waiting to be fitted
all GENUINE VW
spark plugs
pollen filter
cambelt full kit
water pump
aux belt
sump plug/washer
MAF sensor
temp sensor
thermostat
new coolant etc
then the extras that are sat waiting to be done
fuchs titan pro fully synth oil
dimpled /grooved disks front and back
mintex pads front and back
osram night breaker plus dipped and main and fog lights
new genuine vw aerial seal
new aerial stem
new number plates with GTI centre name at bottom
cone filter
forge 007p
Offline davemk4
« Reply #3 on: 27 December 2012, 22:11 »
few trinkets
richbrook tax disc
and new plates
starting next week on the service work
Offline davemk4
« Reply #4 on: 07 January 2013, 20:57 »
so update time
state of disks as you can see major need of changing
the underside mighty clean the underseal and care on these mk4s are really good
poxy intercooler this wont be changed untill abut later on more summer time as i wanna get the car back on road now
current state
ive changed every bulb in heads lights all to osram nigh breaker plus lamps even the fog lights
Offline davemk4
« Reply #5 on: 17 January 2013, 21:20 »
ok so update. in no order
vr6 sachs clutch and g60 lightweight flywheel fitted
new vw gearbox oil
couple of breather pipes replaced
new non orange indicator bulbs (front)
front koni shocks and h+r springs
creation motorsport intake hose (not the best of fits to say they meant to be the best along side forge)
heat shield trial fitted due to above hose it wont line up right
piccies
new
bulbs old
new
intake hose
and koni
only managed a quick start up due to ongoing saga with air con pump first wrong one sent from here, 2nd from ebay sent seized to hell so on my third one now should be here soon then that side of car finished. we hope!
Offline davemk4
« Reply #6 on: 26 January 2013, 08:19 »
new toy  :cool:
the build quality is fantastic. fitting this today if all goes well start up video too  :cool: :cool: :cool:
engine nearly complete
Offline davemk4
« Reply #7 on: 31 January 2013, 23:12 »
Well update time. Where do i start. She started first time quite as a mouse  :cool:
The jetex cat back is a fantastic piece of kit. Is 2.75" straight through to the tips. BUT it not as good a fit as it should of been. The tips were abit far to right meaning the hole we cut like a 4motion wasnt enough the tips banged on the chassis but even then it was 2mm off the rear spring!
Dad saved day by re positioning the hanging bracket on the box and with abit of adjusting it now sits as it should.
Noise wise as id expect. Lovley tone on idle. Not over loud inside. Under throttle nice spirts tone.
Forge dv as good as ever. Nice tishhhhh sound.
The induction set up looks fantastic. Heatshield finishes off lovley. Nice deep tone on throttle.
Car returned to me garage to finish final bits. To find the coil pack wiring was shot. So new loom fitted. What a pig thst was!!!. New aerial stem and seal fitted.
Koni suspension with h&r springs are spot on. Looks lowered but gives a smooth firm ride. Very happy with it.
3" custom front pipe booked 15th of feb. It will be 3" down to a flange with a flanged decat pipe. My oem cat will have flanges fitted to allow easy mot passing. Also means the system isnt a mixed bag of sizes. It will be 3"-2.75" that it.
Pics to follow over weekend
Offline davemk4
« Reply #8 on: 05 May 2013, 20:41 »
long time no update  :sad:
as promised the 3'' custom decat with drop in free flow cat and drop in decat
car miles better. turbo noise and far quicker spool
the car as a whole running great. my center dash display is/has packed up. that summit ill sort later  in year.
today got cracked on with the common mk4 issue
picked a replacement tailgate up in my colour rust free few month back from local scrappy. spent day sorting washer pipe/loom and treating the inners to protect for the future. greased up etc. handle removed and treated any bits of corrosion etc
once everything set and dry will swap boots over and then fit a new genuine anniversary badge to match my............
after this the next list for this year
sort none working door module/puddle light issue
r32/anniversay spoiler
vortex or anni front spoiler
anniversary side skirts
FMIC
stage 2 map
and that be it i hope before missus kills me  :laugh:
Offline davemk4
« Reply #9 on: 30 May 2013, 11:14 »
up date again
r32 spoiler (rep) sprayed and fitted its the little things that really make a car love this spoiler  :cool:
before
after
 :cool: :cool: :cool: :cool:
serviced forge 007p to new revised version (didnt know they had changed)
difference is the piston is a new shape they had issue with the piston leaking boost we will see how it goes!
