Author Topic: MAF question?  (Read 1699 times)
Offline mar_k
Re: MAF question?
« Reply #10 on: 18 December 2012, 19:41 »
VW ones are Bosch?
But they are new, The Euro car parts Bosch units are reconditioned and don't last.
Offline markallen
  • AUM 1.8 20v Turbo 150bhp for now ;)
Re: MAF question?
« Reply #11 on: 18 December 2012, 20:00 »
Are right sweet :) cheers
Golf Mk4 GTi Turbo, R32 front bumper, Lowered on ProSport Coilovers, Bora illuminated vents, Armrest, Heko wind deflectors, Aluminium vinyl trim.
Soon to be added, FMIC, 3" exhaust, Remap..oh and new turbo :(
Offline dom
  • Back in a Mk4
Re: MAF question?
« Reply #12 on: 18 December 2012, 21:05 »
VW ones are Bosch?
This.
Offline markallen
Re: MAF question?
« Reply #13 on: 19 December 2012, 09:53 »
This what? Ha ha
Offline xxChrisxx
Re: MAF question?
« Reply #14 on: 19 December 2012, 10:40 »
Having already spunked £75 quid away, why don't you do a more thorough investigation before splashing out on a new MAF. Unplugging it is not the be all and end all of diagnostic tests.
Quote
Thanks mate. Did you have a rough idle at around 800rpm? When I increase it to about 1200rpm it seems to be fine?
Does not scream dead MAF to me. It sounds more like a vac leak, or a dirty throttle body or injectors.
Your best bet is to find a man with VAGCOM and do a WOT run from 1k-redline in 3rd, logging MAF voltae/airflow readings.
(Only in a safe spot, coz speeding for diagnostic tests is bad mmmkay). Reading in g/s should be approx 0.8*power output.
« Last Edit: 19 December 2012, 10:46 by xxChrisxx »
Offline markallen
Re: MAF question?
« Reply #15 on: 19 December 2012, 11:14 »
Ok mate :) cheers. Seems to start up and run fine this morning. I cleaned my MAF yesterday? Will see how it goes. If it develops again I will fined someone with Vag Com. As for the £75 it came up with Camshaft Position Sensor on the fault code reader so best to get it done ha ha.
