Author Topic: hi guys 1.4 abd starting problem  (Read 3894 times)
Offline dubpirate
« on: 16 December 2012, 15:34 »
hello
only got my new golf yesterday
ok so when its warm it starts fine
wen cold in the morning it fires mint rhen dies
and keeps doing it i have to keep my foot on the throttle to keep it going
after a while it settles and is fine
Offline itavaltalainen
Re: hi guys 1.4 abd starting problem
« Reply #1 on: 16 December 2012, 16:10 »
any fault codes stored or can you do log drive?
could be temp sender, posted an image here not too long ago. just go through last few threads....
Offline dubpirate
« Reply #2 on: 16 December 2012, 16:16 »
my temp guage also dosnt read at all could this be the prob
any idea of part code cannot seem to find one for my car
even puttin reg in gsf or ecp
« Reply #3 on: 16 December 2012, 16:53 »
temp sender unit 357919501A, this has been superseded but if you google the part number you're sure to find something.
your temp gauge not reading can only be down to three things:
thermostat not closing, then heating will be poorer (but usually still work somewhat)
temp.sender unit -this is a dual sender unit, one going to ECU the second the instruments
electrical issue (wiring or instrument cluster)
check my previous posts here. there is an image that would allow you to measure the sensor!
Offline dubpirate
« Reply #4 on: 16 December 2012, 17:06 »
brill pal orderd a coolant temp sensor cheers
thermostat has ust been done i looked at that first no change and heaters work normal
any part no or info on the other sensor your on about
thanks dan
« Reply #5 on: 16 December 2012, 17:17 »
Temp sensor is a dual unit, i.e. two NTC resistors in one housing ;)
Probably gets clearer with photo:
Offline dubpirate
« Reply #6 on: 16 December 2012, 17:21 »
right so the coolant temp sensor i have arderd does both or am i being dumb pal lol
thanks for the help anyhow
« Reply #7 on: 16 December 2012, 17:48 »
yes, does both
Offline dubpirate
« Reply #8 on: 25 December 2012, 17:32 »
ok guys sensor replaced still wont start without aid from throttle and still no temp guage
any other ideas
thanks
Offline search
« Reply #9 on: 25 December 2012, 22:21 »
might sound daft but trust its happend to me on another car with another sensor I ordered a new one and much like you no luck still confused.... long story short turned out the wireing was corroded.... the truth it one fault could be 100 different reason your best of getting it on a vag com machine.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
