Author Topic: how hard is it to fit lockwood dial covers? and brake question  (Read 2192 times)
Offline davemk4
i really like these as look like ani clocks
http://www.ebay.co.uk/itm/400323356569?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
now i know the clocks easy to get out BUT 2 things will disconnecting them cause any coding issues with immob? and how hard is it to take the needles off i dont wanna mash all my dash up fitting them? any one got pictures of how these or the white ones look lit up etc?
also ordering new brakes all round now i can get a good deal for all genuine front disk and pads and rear disks and pads for about £120.00 inc vat but i want a better looking set so was looking at these and wondered what you guys thought?
http://www.ebay.co.uk/itm/170595597043?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
cheers peeps
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Dalo Harkin
Re: how hard is it to fit lockwood dial covers? and brake question
« Reply #1 on: 16 December 2012, 15:11 »
you have to be very careful with discs off ebay, i bought some years ago and they warped in months, ended up going back to solid discs with EBC red stuff pads
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 16 December 2012, 15:20 »
Make sure all the icons line up with yourself on the foils, there are quite a few variants. It's not too hard, just a bid fiddly with the needles
Offline davemk4
« Reply #3 on: 16 December 2012, 15:27 »
yes ive just relised that the ones ive linked to are not right for my mk4 looks more like for a TDI version
Offline Dalo Harkin
« Reply #4 on: 16 December 2012, 15:33 »
I saw the rev range went to 5K and realised they were diesel ones  :wink:
Offline davemk4
« Reply #5 on: 16 December 2012, 21:17 »
Right lockwood website list 2 types..... one for mk4  with monometer display ..... one for mk 4 inc GTI with v.d.o display.
Confused both look like my dials apart ftom the none gti has hashed lines for red limit like my clocks. Gti ones list as solid red line.
Tgey say part number on dials either hh or kkk im confused
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 17 December 2012, 17:42 »
there are loads of different variants; VDO, immo2, immo3, Motometer...
Offline davemk4
right this is a picture of my dials
and based on that i assume this is right set?
http://www.lockwoodinternational.co.uk/golf-mk4-dials-part-no-45hh-more-details-i3846.html
« Last Edit: 28 December 2012, 03:11 by davemk4 »
Offline navmk4gti
« Reply #8 on: 27 December 2012, 23:26 »
Uv changed your clocks to purple cold air feed ends :huh:
Offline davemk4
« Reply #9 on: 28 December 2012, 03:11 »
Yer direct swap too :grin:  post edited  :smiley:
