Author Topic: Strange air leak  (Read 1791 times)
Offline Rob Zombie
Re: Strange air leak
« Reply #10 on: 14 December 2012, 13:27 »
lol!   :cool:
got a work "shindigg" tonight but will take the pipes out tomorrow (with a hangover) and see where the hissing is coming from - hopefully it's an easy fix!
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline Rob Zombie
« Reply #11 on: 15 December 2012, 16:28 »
Found the culprit,
When I took the covers off, I could see what appears to be s0me sort of plug on the end of the pipe I circled in the picture above.mit seemed to have popped out... There doesn't seem to be any clips to hold it in.
So I just taped it up until I can get a bit of day light to take the bracket off to get a better look.
Seems to be fine now now:)
BHP: 231
TRQ: 251.7 lb-ft
Offline Dalo Harkin
« Reply #12 on: 16 December 2012, 14:25 »
if it is part of the brake booster then no they are not held in with anything, even the one on the master cylinder is just pushed in
Offline Rob Zombie
« Reply #13 on: 16 December 2012, 14:45 »
What would you recommend on hold tht puppy in?
BHP: 231
TRQ: 251.7 lb-ft
Offline Dalo Harkin
« Reply #14 on: 16 December 2012, 15:12 »
it should just push in, I have seen some with a piece of rubber around the pipe to make it snug but I dont have the same engine so couldnt even check for you
Offline Rob Zombie
« Reply #15 on: 16 December 2012, 22:24 »
I'm sure there's a few things I can do - I've placed a bit of tape round it at the moment just for temporary measures until I think of a decent solution  :evil:
BHP: 231
TRQ: 251.7 lb-ft
