Author Topic: Strange air leak  (Read 1793 times)
Offline Rob Zombie
Strange air leak
« on: 13 December 2012, 17:37 »
Hi guys
In getting a strange air leak... It seems to be from the pipe on the right just behind the manifold.
When I pull it up, the car starts to idle nicely again.
Can anyone help with wht pipe this is?
Any help would be appreciated
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline GTI.T
Re: Strange air leak
« Reply #1 on: 13 December 2012, 18:47 »
just a rough guess sounds like your vacum hose
Offline Rob Zombie
« Reply #2 on: 13 December 2012, 19:10 »
Okay cheers - when I pull it up - it stop hissing. Quite strange :s
BHP: 231
TRQ: 251.7 lb-ft
Offline Rob Zombie
« Reply #3 on: 14 December 2012, 11:36 »
Hi Guys,
Finally managed to graba  picture of my engine bay and circled where the problem lays in the photo below. If i pull the pipe up, the leak stops. It only starts again if I give the car some beans.
Can anyone advise if they ahve come across this problem before - or part numbers for this pipe etc?
« Last Edit: 14 December 2012, 11:38 by Rob Zombie »
BHP: 231
TRQ: 251.7 lb-ft
Offline GTi_James
« Reply #4 on: 14 December 2012, 12:08 »
replace that with a catch can, problem solved
Offline Rob Zombie
« Reply #5 on: 14 December 2012, 12:22 »
Thanks mate - can you advise whatt he pip actually is and what's it function? what would the catch can do to sort my problem out?
I'm new to the mk4's you see!  :grin:
Ta
BHP: 231
TRQ: 251.7 lb-ft
Offline Dalo Harkin
« Reply #6 on: 14 December 2012, 12:49 »
looks like a brake booster pipe to me  :undecided:
but its a different engine to mine so unless it links into the PCV somewhere...
Offline GTi_James
Offline Dalo Harkin
« Reply #8 on: 14 December 2012, 13:23 »
PVC system
Not more window sellers  :grin:
Offline GTi_James
« Reply #9 on: 14 December 2012, 13:25 »
