Author Topic: wont go past 4500rpm  (Read 3060 times)
Offline petercolston
« on: 12 December 2012, 19:50 »
can someone please help!!!!
just got myself a mk4 gti 1.8 turbo now the car starts fine and idles fine but when i power away the car judders a little
and when i get to 3rd gear i cant get past 4500rpm.
 has anyone had this problem or help me thanx
Re: wont go past 4500rpm
« Reply #1 on: 13 December 2012, 11:02 »
Get it scanned for fault codes but it is in safe mode at the moment.
Offline Luke1981
« Reply #2 on: 13 December 2012, 18:02 »
Faulty maf sensor maybe!
MK IV GT TDI 150 PD / MKII CADDY SDI
« Reply #3 on: 13 December 2012, 21:47 »
got no lights coming on and did put sts in the fuel and its helped a bit someone has said try the fuel filter
« Reply #4 on: 13 December 2012, 23:39 »
Makes no difference if the light is on or off, scan it for codes or else you could spends ages trying to fix it.
Offline Len
« Reply #5 on: 14 December 2012, 08:51 »
Codes dont always help! My Passat 1.8t is playing up big time and no codes showing!
www.sas.org.uk
www.the-ace.org.uk
Offline Agreeable Slick
  • Unit
« Reply #6 on: 14 December 2012, 12:58 »
Juddering is usually coil packs or ignition amplifier.
Scan it - if no codes come back then I would look at replacing coil packs or ignition amplifier. My V5 used to judder like mad under accel and didn't bring a code back. It wasn't until I changed the ignition amplifer that it solved the problem.
Offline Chris.
« Reply #7 on: 15 December 2012, 01:17 »
ignition amp would cause it to run on 3 most of the time...even of idle...same with a coil pack from experience.
Could be a really weak fuel pump.
Whats it do it you have it in 4th/5th gear and floor it from about 2000rpm?  Stutter then?
Click For Build Thread
  • Unit
« Reply #8 on: 15 December 2012, 13:37 »
Not from my experience. It would judder under load then clear under cruise conditions.
Offline vrsjaw
« Reply #9 on: 25 December 2012, 14:44 »
i had ame prob it was try fuel pump,,,coils to
