Author Topic: Mk3 gti handling like a dog  (Read 1825 times)
Offline Baggie21
« on: 12 December 2012, 03:02 »
Recently came back to the vw world and purchased a mk3 gti drives like a dream until you find a left corner where all of a sudden it turns into a boat and the back end lifts up and almost spins out.... Just replaced a OS drop link due to it snapping off, all the shocks and springs are working as normal. Anyone got any ideas? Cheers Matt :)
Offline JC
  • Back in the North.
Re: Mk3 gti handling like a dog
« Reply #1 on: 12 December 2012, 05:37 »
 :laugh: mk3 handling like a boat  :grin:
hat , coat , keys gone >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 12 December 2012, 08:59 »
Basically if its still on the tired old standard shocks and springs nothing more needs to be said than -   Utter sh!te.
« Reply #3 on: 12 December 2012, 09:53 »
Well it is a mk3 and they were poor from new, start by fitting a good quality spring and shock kit plus all new top mounts.
Offline tweed
« Reply #4 on: 12 December 2012, 11:12 »
Yes change them.
I used to get the rear inside wheel up and the front used to bounce under load because of the poor damping of the shock.
It's as if the shock doesn't match the spring rate
Offline Len
« Reply #5 on: 12 December 2012, 12:59 »
I think dogs handle quite well!
www.sas.org.uk
www.the-ace.org.uk
VW BUSH
« Reply #6 on: 12 December 2012, 18:11 »
Rear beam bushes when gone make the back end bounce around all over the place.
Sounds like you have worn suspension components if its that bad.
Mk3 is under damped, just need stiffer dampers and or springs to get it handling tip top
