Author Topic: MK2 golf gti 90 no spark  (Read 5299 times)
Offline Jonoyorko
« on: 11 December 2012, 22:41 »
Hello, ive just recently had put another engine in my car, better cleaner engine. All was going well until we tried to start her! We have no spark! changed coil, rotar arm dizzy cap, ECU and Module checked earths the lot! Been having another go this evening and checked all electrical terminals with the right testing gear, all is good to the coil then still no spark! any help would be very gratefull.
Thanks
Jono. :smiley:
Offline Gambit
Re: MK2 golf gti 90 no spark
« Reply #2 on: 12 December 2012, 11:24 »
are you missing the earth strap from behind coil onto block
Offline Jonoyorko
« Reply #3 on: 12 December 2012, 12:53 »
Compression doesn't have anything to do with not
Sparking or does it?
Earth strap to coil and block is fitted.
Offline Jonoyorko
« Reply #4 on: 12 December 2012, 12:57 »
Offline clipperjay
« Reply #5 on: 12 December 2012, 15:26 »
Hall sender caput?
King lead spark?
Any of the leads spark?
I had to change two coils over due to being duds rubbing my hair that night for sure?
Offline Jonoyorko
« Reply #6 on: 12 December 2012, 18:36 »
Hall sender caput?
King lead spark?
Hall sender is working done the test on it.
No spark at plug or the king lead, it was all
Working fine until Change over.
Offline clipperjay
« Reply #7 on: 12 December 2012, 18:49 »
You have voltage going to the coil terminals right?
Offline devilscaff
  • allways up for alaugh
« Reply #8 on: 12 December 2012, 21:06 »
Is the dizzy set right?
Offline Gambit
« Reply #9 on: 12 December 2012, 21:37 »
Dizzy wont make a difference if he is getting no spark on king lead.
Are you getting pulse on coil trigger wire when cranking?
