Author Topic: MK2 golf gti 90 no spark  (Read 5297 times)
Offline clipperjay
Re: MK2 golf gti 90 no spark
« Reply #20 on: 13 December 2012, 22:51 »
Weird would expect king lead to have something guessing its been wired up wrong and its earthing on the chassis near the coil iteself somewhere?
Earth strap should be on the coil holder to firewall rest should be straight forward?
The earth strap is from the coil holder onto engine block!?
Depends Ive seen them bolted to firewall but need to get some voltage readings when it pulses it might be there but not strong enough to charge coil?
Offline Jonoyorko
« Reply #21 on: 16 December 2012, 21:28 »
Hi all just to let you all no that the beast
Finally started today, believe it or not it was a
Dodgy earth after spending hours scratching heads
And retracing wires we finally got it going only thing
Is the stupid heater matrix went and car filled with steam!!
So back at again tomorrow and hopefully bring her home!
Thanks for all your help and tips
Merry Christmas :grin:
Jono
Offline GOLF-MK3-GTI
« Reply #22 on: 19 December 2012, 14:10 »
Jono
Great Stuff, Where is this earth, which was causing the problem??
Offline Jonoyorko
« Reply #23 on: 01 January 2013, 18:26 »
It was the main ECU loom earth with a few wires attached hadn't been connected properly!!
