Author Topic: Golf gti not cranking over  (Read 1349 times)
Offline TH3M4DH47TER
« on: 11 December 2012, 18:18 »
Hi all,
What it is, is i while back i bought a 1997/1998 Golf GTI 2.0 16V, when i bought it it wasn't running as the bloke had got water in the ignition coil, i intended to use it but due to the high insurance decided not to, so it's been stood the last time i started it was a month ago, it was slow starting due to the immobiliser which i believe is an aftermarket one but i don't know as the alarm system on it is aftermarket (foxguard) and we've had no end of trouble with the immobiliser and alarm, all of a sudden the car will not crank over and the indicators start flashing saying the alarms going and the immobiliser is active, but no amount of pressing of the buttons on the fob will stop this the fobs have had new batteries, and i was even told by the seller to put one key in the ignition and press the button on the keyfob, did that but to no avail, after spending hours and hours trying to workout what it is to find 3 different things that could be wrong.
1.) Starter motor dead
2.) Immobiliser problems
3.)Ignition barrel wiring dodgy
tomorrow i will be checking to see if it is a dodgy starter (I'll try hotwiring it to see if it cranks) but i'm not holding my breath with that, I've read about bypassing the immobiliser is this possible?? if so how would i go about it because i would love to get my Mk 3 on the road so i can do a VR6 conversion to my Mk2 (if anyone could give me the name of a company that would be able to sort it out for me i'd be over the moon or any details on how to do the bypass) and I'll be checking the back of the ignition barrel for dodgy wires because when i turn the key only ignition lights come on. i don't think the car has a transponder key as the seller had the original key and a spare key which had been made up the day before, that was a little tight but would turn the car on.
If anyone could give me some advice about this problem it'd be amazing
thanks
Offline spikenipple
Re: Golf gti not cranking over
« Reply #1 on: 11 December 2012, 18:36 »
Charged your battery up? Checked the fusebox?
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 11 December 2012, 19:01 »
Ignition switch are a common failure in the mk3 they are very cheap to replace.
Offline spudboy6
  • Just like a golf ......
« Reply #3 on: 14 December 2012, 00:05 »
And a pain in the arse .....
Offline Len
« Reply #4 on: 14 December 2012, 08:53 »
Have you checked the battery terminals are tight and have a good connection?
www.sas.org.uk
www.the-ace.org.uk
Offline madmanmart
« Reply #5 on: 14 December 2012, 17:30 »
Turn the ignition on and then take a piece of wire from the battery +ive to the starter moter crank wire (the small black plug on the starter motor).
This will determine if the ignition switch is faulty........
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
