Author Topic: No dash/instrument lights - Update  (Read 1226 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 11 December 2012, 17:20 »
My brother wired in a boost gauge incorrectly, from what he tells me I think he wired in the live and then connected it to the the other wire coming from the dimmer switch INSTEAD of earthing it...Tit.
Now his instrument lights don't work (warning lights work but not the blue glowing ones for the dials/radio), checked all fuses and they are fine. Although he popped the brake light and central locking one which will get replaced....
The coil light was flashing (130PD ASZ by the way), which led me to believe the brake light switch, but this turned out to be fine after borrowing a fuse from mums car.
Any ideas on the cluster/radio back lighting?  :sad:
« Last Edit: 12 December 2012, 18:58 by scarr89 »
Offline scarr89
Re: No dash/instrument lights
« Reply #1 on: 12 December 2012, 07:02 »
Possibly thinking wiring it incorrectly could have blown the dimmer switch? Going to replace and see what happens...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 12 December 2012, 07:15 »
I'd say yes to that mate as the lights don't come on if you have the dimmer switch unplugged
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #3 on: 12 December 2012, 08:44 »
I'd also go with dimmer switch, let us know how you get on?
Offline scarr89
« Reply #4 on: 12 December 2012, 18:57 »
Brother borrowed mums dimmer switch and still no joy.  :undecided:
Could he has fried/pop all of the bulbs for the radio/cluster!?  :huh:
All fuses checked and replaced, everything else is working fine...Stranngeeeee
Offline Golf_GT_TDI
Re: No dash/instrument lights - Update
« Reply #5 on: 12 December 2012, 20:01 »
Got a multimeter handy? quick test to see if you're getting voltage from the grey/blue wire from dimmer switch
Offline scarr89
« Reply #6 on: 13 December 2012, 13:58 »
Ok, there is power to the dimmer switch as when FULL beam put on the cluster and radio backlights come on, then when FULL beams turned off they disappear again.
I am really stumped. Will check all the wiring for a short circuit. Could it be the earthing for the dimmer switch isn't sufficient, hence why you would need full beam to make it work? Or something similar?  :undecided:
Offline harlemex
« Reply #7 on: 13 December 2012, 14:22 »
where did he wire in the actual live?
Offline scarr89
« Reply #8 on: 13 December 2012, 14:56 »
There are two wires coming out of the dimmer switch right? He just wired those 2 (not sure which way around) into the 2 wires coming from the boost gauge.  :sad:
He should have asked big brother eh!  :lipsrsealed:
Offline harlemex
« Reply #9 on: 13 December 2012, 15:30 »
hmmmm tricky one. I would try them the other way around first.
