Author Topic: Sub Advice Please  (Read 4754 times)
Offline salsheikh
Sub Advice Please
« on: 10 December 2012, 12:49 »
Hi Guys,
I currently have a Vibe 12CBR sub/amp combo in my car and although it sounds great it gives me a nice drone. Now I want to go from drone to THUMP so am i right in thinking i need to get a 10" sub to do this?
Thanks
Offline Len
Re: Sub Advice Please
« Reply #1 on: 10 December 2012, 13:23 »
Not necessarily.
Depends how your current 12" is set up. What kind of enclosure is it in?
www.sas.org.uk
www.the-ace.org.uk
Offline tshirt2k
  • Been there...Done that...
« Reply #2 on: 10 December 2012, 15:42 »
Enclosure will make biggest difference. A sealed enclosure should give more punch. Although ported are more efficient and tend to give long low bass depending how the box is tuned.
Mk3 ABF 16VT Megasquirt V3
Offline salsheikh
« Reply #3 on: 10 December 2012, 19:36 »
its a vibe cbr 12 unit with 2 ports that can be blocked off using port plugs.
similar to this:
http://www.ebay.co.uk/itm/VIBE-CBR-12-/271117455273?pt=UK_In_Car_Technology&hash=item3f1fdc0fa9
Offline Len
« Reply #4 on: 11 December 2012, 13:22 »
Cant see it at work (no ebay) but I bet its ade from thin materials which are probably resonating away and confusing the sound.
www.sas.org.uk
www.the-ace.org.uk
Offline salsheikh
« Reply #5 on: 11 December 2012, 21:10 »
tbh the mdf thickness isnt bad at all and it is a very heavy box
Offline Len
« Reply #6 on: 12 December 2012, 12:45 »
That will mostly be the weight of the speaker!
My advice would be to sort a really good, solid box and then see. But make the front so you can change it.
If you still dont like it then you can change the front for a different diameter hole one and try a 10"
I have a 10" speaker cant remember which one off hand. I'll post again when I find the thread
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #7 on: 12 December 2012, 12:47 »
Diamond Audio
www.sas.org.uk
www.the-ace.org.uk
Offline salsheikh
« Reply #8 on: 13 December 2012, 14:04 »
i took the speaker out and the thickness is 15mm mdf so its a decent box from Vibe.
Tonight I am gonna try a 10" vibe amp/sub combo (similar to mine) to see if the bass is different
Offline tg1
« Reply #9 on: 14 December 2012, 17:09 »
a sealed box should do the trick
