Author Topic: Steamy windows!  (Read 3806 times)
Offline devilscaff
  • allways up for alaugh
Steamy windows!
« on: 09 December 2012, 21:29 »
Now driving the car in less than summer conditions,lol. The car is running great and even starting at -2 and covered in frost, I'm noticing when returning to the car after a short while the whole car steams up almost instantly. I'm putting the fan on but even on three it would barely blow out a candle,and to say the rear demister is slow would be an understatement. Does anybody else suffer this and if so any tips to help would be greatly appreciated thanks
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Steamy windows!
« Reply #1 on: 09 December 2012, 21:45 »
Common issue I'm afraid...
The MK2's are designed to let water into the doors and this can cause issues with the membranes shrinking or leaking...
Tailgates leak too..
Best to have the door cards off and check when the better weather arrives...
For More Info Click To See;
Offline Jimmyrallye
  • 20vt goodness
Re: Steamy windows!
« Reply #2 on: 09 December 2012, 23:34 »
Mines the same  :cry: plus a dodgy heat matrix its not fun in my car at the mo
Offline dannyxr2i
Re: Steamy windows!
« Reply #3 on: 09 December 2012, 23:44 »
i have my rear windows down a bit and this cures it, joys of a mk2 in the winter months i think.
Offline devilscaff
Re: Steamy windows!
« Reply #4 on: 10 December 2012, 06:31 »
Oh great least I'm not the only one, unfotunatly mines only a two door so no rear windows to open. Gonna have to buy a good squeegee!!
Offline sparkplug
Re: Steamy windows!
« Reply #5 on: 10 December 2012, 16:55 »
mine too  :sad: did all 4 door membranes ,last month & put grease around the rear light seals
but i think my heater matrix is venting steam into the car ,gonna have to change it asap  :rolleyes:
1986 GTI atlas grey
Offline Gambit
Re: Steamy windows!
« Reply #6 on: 10 December 2012, 18:08 »
if the car has had any sort of water leak at any point in time then you can guarantee the under felt in the carpets is damp. the issue here is that it has a rubber membrane between carpet & underfelt, so no matter what you do it will never dry out EVER
you need to strip out the carpets & under felt, & dry it all out properly
other places that cause leaks are from below the scuttle if the drainage holes arent clear, also sunroof drainage channels.
if you can leave your car garaged for a week or so, fill a bowl full of salt (the big 2kg bag) and leave the bowl sitting in the passenger footwell with all windows fully up (ie as air tight as possible) the salt will draw any moisture out of the cabin & into the salt.
« Last Edit: 10 December 2012, 18:10 by Gambit »
Offline Mr Blue
Re: Steamy windows!
« Reply #7 on: 10 December 2012, 18:54 »
I used carlack glass sealant on the inside and get barely any mist. Only slightly mist when you bring in water with shoes now. Once up to temp and heaters pointed to windows the class is clear  :smiley:
I did use sound deadning as a door membrane so that is another big help.
Offline clipperjay
Re: Steamy windows!
« Reply #8 on: 12 December 2012, 10:47 »
Stop shagging in the rear seat helps gets quite steamy  :tongue:
Offline devilscaff
Re: Steamy windows!
« Reply #9 on: 12 December 2012, 17:38 »
You must be joking been married twelve years!
