Author Topic: battery problems again  (Read 1069 times)
Offline shaft69
« on: 06 December 2012, 21:54 »
When diving battery going flat had problem before replaced alternator and fuse box on top of battery cos melted on lead that goes alt. Fitted new lucas alt and fusebox on battery been ok, had new clutch fitted today happened again on way home. Found both battery leads were loose so tightened started car and lead from alt to fusebox at fusebox very hot and melted it again. Has anyone had this problem or know about it?
Thanks
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline jonnyturbo
Re: battery problems again
« Reply #1 on: 07 December 2012, 17:36 »
Never heard of the melting before
Offline gti gurl
« Reply #2 on: 07 December 2012, 18:00 »
yes that happened to mine a few weeks ago so other half swapped the fuse box with his as its off the road but the (brand new) battery still never held its charge so had the AA come out and at first thought he thought it was the alternator but it turned out it was the lead connecting from the battery to the alternator. Lucky for me he was nice enough to change it and ever since its bee fine (touch wood) :smiley:
Im no cactus expert but i know a prick when i see one !!!
Offline shaft69
« Reply #3 on: 08 December 2012, 23:29 »
Fuse for alt burnt out replaced fuse, alt earthing out inside so put one on from car I'm breaking. Took other one back to ecp going to order fusebox and lead from fuse to alt.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline GTi_James
« Reply #4 on: 09 December 2012, 09:24 »
you getting your robot slave to type this for you?  :laugh:  :kiss:
Offline baxxy
« Reply #5 on: 11 December 2012, 11:35 »
 :laugh: :laugh: :laugh:
