Golf mk6
Snoopy
Milltek
Topic: Milltek (Read 1937 times)
smoggy
2011 Golf GTI *DSG*
Milltek
06 December 2012, 18:04 »
Hi,
I have a VWR exhaust which is made by milltek it has 100mm tips at the moment, fancy changing to 90mm anyone done this ?
2011 Gti * dsg * sat-nav * r-pack * etc
Ginge 35Edition
Re: Milltek
06 December 2012, 18:09 »
Pics?
smoggy
2011 Golf GTI *DSG*
Re: Milltek
07 December 2012, 06:19 »
VWR badge now removed and replaced with standard gti badge.
Y444GAR
Guest
Re: Milltek
07 December 2012, 08:44 »
Your exhaust is hanging down, my milltek with 100mm tailpipes was tucked up into the diffuser. Dont think its the size of the tips thats the problem.
Last Edit: 07 December 2012, 08:52 by Y444GAR
smoggy
2011 Golf GTI *DSG*
Re: Milltek
07 December 2012, 09:50 »
Do you mean that its sitting too far out from the diffuser ?
mkviken
Re: Milltek
07 December 2012, 11:33 »
they do look like theyre sticking out loads
mine are the same tail pipes and i have mine flush with the diffuser.
also when the system heats up they will stick out even further
by the way you seem to have a gay pride flag on your number plate
Golf GTI 7.5 230 white silver
smoggy
2011 Golf GTI *DSG*
Re: Milltek
Reply #6 on:
07 December 2012, 15:29 »
Looking better now i have just moved them back by a few inches
.....managed to snap the bolt off the clamp though, so had to use an exhaust u bracket to sort it.....
ErikGTI
Re: Milltek
Reply #7 on:
10 December 2012, 15:38 »
I went from 100 mm Miltek to 90 mm Fox and the difference between this 90 mm and standard 80 mm is still HUGE.
I personally like the OEM look...you are still in doubt unless you spot a standard GTI exhaust
Mind you in the end it is all a matter of taste....however on pics the 100 mm is a nobrainer
Last Edit: 10 December 2012, 15:50 by ErikGTI
I'LL BEAT YOU TO THE BBC STUDIO........
ErikGTI
Re: Milltek
Reply #8 on:
10 December 2012, 15:43 »
It looks like the 90 mm pipes stick out but that is not the case in fact I took care that they stick out as much/less as the original...meaning flush with the diffuser
Btw the 90 mm Fox are welded in the same way the originals were welded (in fact it is now even better welded) the 90 mm ones are nearly twice the length of the original 80 mm ones (which from a side view appeared much more to be a small chrome collar)
Last Edit: 10 December 2012, 15:49 by ErikGTI
Golf mk6
Snoopy
Milltek
