Author Topic: Rear seat rattle...  (Read 3912 times)
Offline javalin
Rear seat rattle...
« on: 05 December 2012, 17:59 »
Rear seat rattling between the split, sounds like the hinge/whatever is loose/worn.
Is there a quick fix for this, or .....?
Ta
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline tweed
Re: Rear seat rattle...
« Reply #1 on: 05 December 2012, 18:32 »
Have a look for a loose hinge. It should make a noise if its pushed down. Maybe pull them up and make sure a seat belt clip isn't hitting body
Offline javalin
« Reply #2 on: 05 December 2012, 20:00 »
ok ta will do
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 05 December 2012, 21:06 »
If its anything like mine ,its where the back of the seat rubs against the plastic trim on either side,wd40 shuts it up.
Offline gtigirlracer
« Reply #4 on: 05 December 2012, 21:11 »
Don't know where to post this as never used forums before. I have a gti mk3 and the engine has cut out twice at low speed lose power steering and brakes , starts again no probs anyone know why its doing this?  :sad:
Offline tweed
« Reply #5 on: 05 December 2012, 22:36 »
Click on "mk3 cuts out after starting" and read what I've put. Search is at top of page
Offline Len
« Reply #6 on: 06 December 2012, 12:57 »
For the seat backs it can only be the middle hinge points.
Seat squabs - check under the front.
www.sas.org.uk
www.the-ace.org.uk
Offline javalin
« Reply #7 on: 06 December 2012, 13:15 »
>Seat squabs
whats that then?
Offline Len
« Reply #8 on: 06 December 2012, 15:18 »
What you sit on! :rolleyes:
That is the correct english term for them
www.sas.org.uk
www.the-ace.org.uk
Offline javalin
« Reply #9 on: 06 December 2012, 15:31 »
yeah its the middle hinge point, I'll check it at the weekend - apparently there should be a clip holding it all together....?
