Author Topic: bbs alloys and corrosion...  (Read 2204 times)
Offline charri42
« on: 18 July 2005, 23:32 »
Hi folks, my MK4 has the optional 16" split rim bbs alloys (an expensive option i believe)
They seem to be a bugger on the outside rim, which isn't a painted finish and corrode very easily. MIne were refurbed about a year ago and are just starting to go again in a few places. Is there anything I can do to stop this? they look amazing right now, but fear that 12 months down the line they will need a refurb.
Cheers,
Chris... or if anyone wants to swap for a nice set of Montreal II?
Hatchet Harry
Re: bbs alloys and corrosion...
« Reply #1 on: 18 July 2005, 23:33 »
is it the laquer peeling off??
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 19 July 2005, 00:16 »
they're known for corroding.. even moreso with the anniversay wheels (bbs rc)
if you've already had them refurbed once then the best you can do is keep them as clean as possible and dont forget to wax them ! also be careful if you use any kind of blacking on your tyres, wipe any overspray off the wheels straight away.
Offline BOGGLE
« Reply #3 on: 19 July 2005, 00:26 »
Would they be better if you had the lips polished :huh: :undecided:
Before....During.....After
Offline Hobnob
« Reply #4 on: 19 July 2005, 10:00 »
Sorry to steal the thread here, but you have mentioned waxing your wheels, can you give a bit more information on what wax to use and what advantage there is from doing this.
Hobnobs......The SAS of the biscuit community
Golf 1.8 T(ARZ) - Reflex Silver - Completely Standard
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 19 July 2005, 10:13 »
there's probably specialist stuff you can buy, but normal clear car wax will work.. builds up a protective layer on the wheel surface.. you'll also find its a lot easier to keep them clean, brake dust just rinses off.
Offline Hobnob
« Reply #6 on: 19 July 2005, 10:32 »
so something along the lines of autoglym extra gloss, or would you suggest a hard wax?
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 19 July 2005, 10:44 »
hard wax would be more durable, but obviously it would be a complete b!tch to apply to fiddly wheels like bbs splits
Offline charri42
« Reply #8 on: 19 July 2005, 23:32 »
cheers, I'll give wax a go. The inner bits are fine (painted) the outer bits seem to be like an etched finish and have that whitey corrosion just starting in places.
Reminds of the wheels on late Scirocco Scalas and late Golf mk 2 cabs. They were notoriously bad too.
