Author Topic: Quick one, Cambelt change ABF  (Read 3449 times)
Offline Leroy
  • Golf GTI Anniversary 16v
« on: 30 November 2012, 12:55 »
How often peeps? Mate says 5yrs or 60k but i wouldn't trust what he says over you guys???
Offline vw_tees
Re: Quick one, Cambelt change ABF
« Reply #1 on: 30 November 2012, 13:11 »
60k would be a good time to change.
Offline Leroy
« Reply #2 on: 30 November 2012, 15:33 »
Mine was last done 4yrs and 33k ago, so im ok for a bit then?
Offline tweed
« Reply #3 on: 30 November 2012, 17:28 »
Mines done 35,000 and ain't been changed sinse 97  :lipsrsealed:
Offline Leroy
« Reply #4 on: 03 December 2012, 09:20 »
When are you going to change yours then Tweed? If the amount of time on the car doesn;t matter are you going to change it after a certain mileage?
Offline Metallix
« Reply #5 on: 03 December 2012, 09:58 »
If the 5 years has elapsed, change it.
A belt & tensioner cost a lot less than fixing the damage caused by a snapped belt.
Including:
  • new valves
    belt & tensioner
    new oil
    new coolant
    head gasket kit
    head bolts
« Reply #6 on: 03 December 2012, 16:02 »
Cambelt should be replaced every 4/5 years regardless of mileage.
Offline Len
« Reply #7 on: 04 December 2012, 12:44 »
I wont be changing the cambelt of my 405Mi16 which has not moved for 7 years!
But yes if the car is used then 5 years max.
www.sas.org.uk
www.the-ace.org.uk
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #8 on: 04 December 2012, 15:16 »
Even if it hasnt moved the rubber could potentially be perished and weakened with age.
Offline GOLF-MK3-GTI
« Reply #9 on: 04 December 2012, 16:44 »
Yes your absolutely right, for example if a brand new tyre is left unused, after a good few years cracks start to appear and it will loose its strength.
Same scenario as a belt. and to be honest, i would not risk it, as my uncle's lexus timing belt snapped and its wrecked the whole engine.
