Author Topic: Black Smoke  (Read 2010 times)
Offline Chris619
Black Smoke
« on: 18 July 2005, 19:11 »
I went to start my car up yesterday and when I turned the key smoke started to come from behind the dash and it smelt of an electrical fire. And now my fog lights donÂ’t work. I checked the fuse for the fogs and, it had blown. When I got to work to day I took some of the dash out to trace the wires to the fog lights and they seam to be ok. Should a blown fuse cause smoke top come from behind the dash, or do I need to check the rest of the wiring loom for fried wires. :undecided:
But to be on the safe side I went out and bought a fire extinguisher today just in case :grin:
Offline monzablue16v
Re: Black Smoke
« Reply #1 on: 18 July 2005, 21:29 »
Shouldn't smoke when fuse goes at all that's why you have a fuse :) Bbut could be that whatever caused the smoke is what caused the fuse to blow usually a short circuit or old wires. The casing gets brittle and cracks, causing a short which makes hot wires which melts off the plastic casing, fuse goes, wire cools,  plastic cools and no evidence of a wire fire But best well check if not replace any affected wires if you have the ability.
Edited in light of fairness and non cruelty  :wink: :rolleyes:
unedited again!
Wouldn't want this happening!
 http://www.filecabi.net/host/file/FlamesGTI/wmv  :wink:
Made me think twice about how wiring should be done~(well and carefully!)
Good buying on the fire extinguisher 1 should be in every car!
« Last Edit: 19 July 2005, 22:41 by monzablue16v »
Offline pegasus
Re: Black Smoke
« Reply #2 on: 18 July 2005, 21:38 »
^^^^^thats cruel^^^^^
1.8 20VT GTI
Re: Black Smoke
« Reply #3 on: 18 July 2005, 21:44 »
Not meant to be mate!
I'm biased Just had a mini and a Bora and a BMW M5 and a T25 van all set on fire whilst sat in them I'm either cursed or it's more common than it seems!
Kinda brings it home though doesn't it?
Offline Chris619
Re: Black Smoke
« Reply #4 on: 19 July 2005, 18:13 »
Got the problem sorted today, it was just a faulty switch nothing serious
Offline pegasus
Re: Black Smoke
« Reply #5 on: 19 July 2005, 18:59 »
No No No, uv got it wrong  :grin:
Totally misunderstood what i meant by it being cruel.... not cruel to post the link, but cruel that such a thing should happen to a lovely mk4
Put the link back in dude  :cool:
1.8 20VT GTI
Re: Black Smoke
« Reply #6 on: 19 July 2005, 22:42 »
Glad it was nothing serious dude missed that one from everything else! :)
