Author Topic: Not even 24hrs and the engine management light is bk on  (Read 2298 times)
Offline hitman_bridger
For my motor sorted last night and it was running perfect. Drove to work this morning and was still good. Left work at lunch and the engine management light came on and now won't boost over 4psi. Other than that its running fine. Any ideas what's up?
Offline GTi_James
Re: Not even 24hrs and the engine management light is bk on
« Reply #1 on: 29 November 2012, 16:28 »
limp mode, do not drive, get codes and post up mate  :wink:
« Reply #2 on: 29 November 2012, 16:46 »
I have to drive it to get home. Only 5 mile. Will this be ok?
Offline GTi_James
« Reply #3 on: 29 November 2012, 16:50 »
...i wouldnt personally mate but if needs must, limp mode is designed to stop any further damage from happening, have you stopped and started again?
could also be a loose connection somewhere so just check all sensor etc as well before you start up again
Offline jamie1989
« Reply #4 on: 29 November 2012, 17:04 »
Whatt!!!
Do drive it!
Its in limp mode as theres a fault, it will run but SLOW. Get it plugged in again you have an issue somewhere. Get a error code throw it up on here and we will go through some possible causes.
You can unplug your MAF and your can will run in LIMP it doesnt mean you cant drive your car.
Just dont hammer it.
Could be any sensor causing your issue.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
« Reply #5 on: 29 November 2012, 17:09 »
Ok thanks will call the aa again lol.
Offline jamie1989
« Reply #6 on: 29 November 2012, 17:16 »
If your stuck somewhere mate trust me if its only boosting to 4psi its running in limp, Drive home and get it sorted. Infact drive home and order a Vagcom lead of ebay for less than £10 it will save you an absolute fortune!!
Its worth the weight in gold.
« Reply #7 on: 29 November 2012, 17:31 »
Will have to invest then lol.
Also have noticed the the small hose coming off the top of my dv is folded right over. Could this be the problem?
Offline jamie1989
« Reply #8 on: 29 November 2012, 17:41 »
post a pic mate
« Reply #9 on: 29 November 2012, 17:47 »
Will have to do it when I get home. Can't do it in my phone for some reason. Thanks for your help tho mate. its much appreciated.
