Author Topic: Not even 24hrs and the engine management light is bk on  (Read 2242 times)
Offline jamie1989
Re: Not even 24hrs and the engine management light is bk on
« Reply #10 on: 29 November 2012, 17:58 »
The pipe your explaining about does it look damaged or preventing the pipe to allow air through it?
If it is then that isnt good as your DV wont be operating properly.
Best bet it replace this pipe anyhow using the ebay 3/4mm silicone piping. Its about £5 delivered.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline dan2252
« Reply #11 on: 29 November 2012, 18:12 »
Yeah it's fine to drive in limp mode it's not gonna hurt it just don't boot it, I'm guessing n75 valve or airflow meter or a boost leak. Oh wait that's what goes wrong with a 1.8t every few days lol
MK4 golf 1.8 turbo agu :)
Offline Nino
« Reply #12 on: 29 November 2012, 18:25 »
If any of the hoses going to the DV are split/bent it can cause it as the boost/air cannot run correctly.
Current - MK6 GTi Edition 35
Offline GTi_James
« Reply #13 on: 29 November 2012, 21:04 »
 :embarrassed: sorry lads i thought you shouldnt drive it in limp mode as it could make it worst  :undecided:
i was fibbed to then  :cry:
Offline hitman_bridger
« Reply #14 on: 29 November 2012, 22:36 »
Well got it home ok. Sorted the hose out. But still low on boost.
Offline GTi_James
« Reply #15 on: 29 November 2012, 23:08 »
all coils/spark plugs, fuel lines etc etc been checked? could be a misfire? get yourself a code reader as well or find a vag specialist and ask him to clear the codes and when you order your reader you can then put the fresh codes up for us  :wink:
Offline Nino
« Reply #16 on: 30 November 2012, 00:02 »
grrr kind of annoying you dont leive near me Id come to you and scann the car just to see whats wrong...
« Reply #17 on: 30 November 2012, 07:16 »
Checked all the hoses, spark plugs,etc. was running fine this morning but engine light was on still. It isn't miss fireing and no lack of power. Just wasn't boosting properly yesterday. Seems ok now just the light is on.
Offline jamie1989
« Reply #18 on: 30 November 2012, 08:30 »
Could be anything mate. Best to get it scanned again.
My quess it will be a sensor pooped itself, something like MAF, MAP or camshaft sensor.
Let us know what it comes up with a scan.
Offline GTi_James
« Reply #19 on: 30 November 2012, 08:32 »
sounds like an engine splutter then, i had one a couple of months back when i had my recall, took it to my mech and ran a diagnostics, old codes were wiped, ran it for 15miles and went back, engine light was on but no issues whilst running, did a full check and was literally down to a hiccup in the engine, never happened since, just the spluttering dying thing i have on cold mornings now  :angry:
