Author Topic: Abf conversion golf feels slow  (Read 4275 times)
Offline Jimmyrallye
  • 20vt goodness
« on: 27 November 2012, 22:55 »
Recently fitted a abf gearbox flywheel ect on my mk2 20vt and have noticed its realy crap compared to the mk2 8v box i took of to replace it with... Got confirmed tonight when my mate spanked me in hes clio182 whilst given it 4 weeks ago i left him in 3rd with the 8v box on ??? Im confused as i thought a abf box with cables wos a upgrade !!!! :( any help or advice would be great :)
Offline dubber36
Re: Abf conversion golf feels slow
« Reply #1 on: 28 November 2012, 10:29 »
I'm sure the 8V box will have much lower ratios. From memory, the Mk2 8V had a top speed of about 115mph at getting towards 6000rpm in 5th. The Mk3 16V had a top speed of 135ish mph at just over 6000rpm.
Your car would have been a flyer with the 8V box, but would run out of revs at big speeds. The ABF box will give you the opposite results.
Offline Gambit
« Reply #2 on: 28 November 2012, 10:36 »
find the ratio's of the mk3 16v box and then compare them on this, there is a handy speed converter included :)
http://www.scirocco.org/gears/
Offline Jimmyrallye
  • 20vt goodness
« Reply #3 on: 28 November 2012, 12:16 »
Thanks dubber and gambit kind of wish i kept the 8v box on now but it kept slipping with the torque ... Car could do with remapping any way and at least the gear change is nice and smooth now !! Guess il be throwing more money at it :)
Offline Sam
  • Sam I am
« Reply #4 on: 28 November 2012, 13:09 »
IIRC you can take the abf 5th and put it  in the 8v with difficulty... or am I thinkning of 16vs or a 4e? or have I made it up  :laugh:
Offline Sam
  • Sam I am
« Reply #5 on: 28 November 2012, 13:10 »
Nope not made up, 4e on a 16v 020...
http://www.brokevw.com/5thswap.html
So research into 8v box possibilities will be worth it
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 28 November 2012, 19:00 »
Yes but the reason for going cable-change is for a more durable box and stronger clutch.
To resolve the 'speed' problem you have you would need to replace the final drive in the CDA box with a shorter final drive.
If you're still running the 10kg flywheel, get that taken down to 6kg as well - will make a significant difference too.
Offline Jimmyrallye
  • 20vt goodness
« Reply #7 on: 28 November 2012, 19:55 »
Yes im running the standard mk3 16v flywheel as i just robbed everything i needed of the mk3 ,, you say changed the final drive do you mean by changeing 5th gear ? As its pants in all the gears if im totaly honest
VW BUSH
« Reply #8 on: 28 November 2012, 20:03 »
What bhp/torque are you running on the 20vt?
If you gear it down now and increase bhp/torque later you will be in a similar situation.
  • Opinions я Us
« Reply #9 on: 28 November 2012, 20:12 »
No, I mean changing the final drive, which sets the gearing of the whole 'box.  Effectively you're making all of the gears shorter.
Good time to put an LSD in if you're that far down the 'box.
Find someone who builds boxes and talk to them about your requirements.
