Author Topic: Golf GTi Mk1 Cab Starting Problem  (Read 4975 times)
Offline Willdub
« on: 26 November 2012, 15:38 »
I've got an F reg MK1 Golf Cab, 1.8 GTi. It starts up from cold perfectly but when you take it for a drive, leave it parked up for awhile and come back to it, it struggles to start. So far it has eventually started after several turns of the key but I am reluctant to take it on long journeys or on stop start trips in case it won't kick up.
It has had many new parts including a head gasket, thermostat, timing belt, water pump, fuel pump, fuel pipe, alternator, spark plugs and injectors. Also, the battery is fine and fully charged, and there is plenty of fuel in the tank.
Thanks
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: Golf GTi Mk1 Cab Starting Problem
« Reply #1 on: 21 December 2012, 07:54 »
Use search as this kind of issues have been covered before.
I would check all earth cables and relays, mainly the fuel relay.
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline SoundillusioN
« Reply #2 on: 31 December 2012, 14:44 »
So it never fails to turn over but does fail to fire when warm?
Warm up regulator?  Caused me similar issues, ran ok when cold and like a dog when warm until I changed it.
Offline gibby
« Reply #3 on: 05 January 2013, 22:30 »
Take fuel relay out, sandpaper the connections and see if that helps. Pound to a penny it will be covered in plastic gunk from the fuse box.
......now officially dubless.
Offline chalky white
« Reply #4 on: 16 January 2013, 19:25 »
Then take a look inside the tank and check the in tank lift pump. A usual suspect  is crud and rust from the filler neck blocking the Gauze at the bottom, so the pump needs to draw more current and this also make the second under body pump work harder too. Replace the fuel filter as well. Check the fuel pump fuse is OK should be 15A. You can get an issue of the above blowing the fuel pump relay fuse so folks put a bigger fuse in which again draws more current.
Relay position 2 No 2
Fuse Position 5 15A Blue
