Author Topic: Slow return to idle  (Read 1623 times)
Offline JimR
Slow return to idle
« on: 25 November 2012, 20:49 »
Hi all,
My 8v pb has an issue with a really slow return to idle when changing gear, it doesn't 'snap' back to idle like it should. Also, when I first start it (regardless of hot or cold), the idle will creep up gradually to about 2500rpm but after a few minutes it idles as it should at around 900rpm, should I suspect a vacuum leak or something else, this one has got me beat, which doesn't happen often!!
Thanks in advance
James
« Last Edit: 25 November 2012, 20:53 by JimR »
Mk2 GTi.
Offline JimR
Re: Slow return to idle
« Reply #1 on: 29 November 2012, 17:50 »
Shameless bump.
Mk2 GTi.
Offline Mr Blue
« Reply #2 on: 29 November 2012, 19:08 »
sounds vacume-ish. Spray carb cleaner around the suspect areas. The revs will rise where there is a leak.
Check the inlet pipe. They always crack and the clutch cable can rub through it sometimes.
Offline JimR
« Reply #3 on: 30 November 2012, 20:33 »
Had been spraying all around with carb cleaner and got no changes, thought I'd give it another go today and sprayed the base of the injectors and et voila, a slight rise in revs. Looks like the inlet manifold is coming off this weekend.
Mk2 GTi.
