Author Topic: Front mount intercoolers  (Read 4168 times)
Offline smally11981
Re: Front mount intercoolers
« Reply #10 on: 18 November 2012, 18:37 »
Thats great info thank u as im a welder i could solve the issue i got 2" ic pipework and yes its an aum mate thank u.
Offline cooki
  • 1.8T AUM
« Reply #11 on: 19 November 2012, 09:26 »
Guys. Save starting a new thread and coz mines the same car and intercooler as smally11981:::
What size silicone is needed for the turbo side of the set up?mines an 02 aum so im guessing its a ko3s turbo??
How can i find out what turbo i have?to no what size i need
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline smally11981
« Reply #12 on: 19 November 2012, 11:04 »
Hey cookie i saw another post in the mk4 section apparently if its an original aum it has a ko3s on it. Have a look it was only on page 2 of the mk4 section
Offline cooki
  • 1.8T AUM
« Reply #13 on: 19 November 2012, 13:09 »
Brilliant mate tar for that just found the thread.
So basically mine is/should be a ko3s.
So does any1 no the size of silicone needed so come off the turbo for my intercooler???
Offline GTi_James
« Reply #14 on: 19 November 2012, 13:29 »
e-bay would have most of those pipes measured for specifics, i havent had any issue with the suppliers taking down a note of my reg and they give me all the measurements for car, no probs
Offline rio_gti
« Reply #15 on: 19 November 2012, 14:32 »
46mm off the turbo (same as k03)
i tried a 51mm and it is proper loose on it
Offline cooki
  • 1.8T AUM
« Reply #16 on: 19 November 2012, 14:41 »
Cheers for that mate. So its 46mm then going up to whatever size pipeing i have then yes???
Thanks again
Offline rio_gti
« Reply #17 on: 19 November 2012, 16:00 »
Thanks again
you got it  :wink:
you got the take off for dump valve and n75???
Offline cooki
  • 1.8T AUM
« Reply #18 on: 19 November 2012, 16:59 »
My pipe is a metal pipe and already has the dv take off on it. So im getting the correct sized silicone joiner and getting a quick tap kit for the n75 valve.
How u doin yours mate??
Offline rio_gti
« Reply #19 on: 19 November 2012, 18:14 »
Gettin them welded on to one of the pipes, just gotta get the right drill bit then give them to a pal of mine  :wink:
Sounds good pics when it's done I hope
