Author Topic: Front mount intercoolers  (Read 4167 times)
Offline smally11981
« on: 17 November 2012, 15:57 »
Hi peeps.
  I started to fit a toyosports front mount intercooler today started to take the factory fitted one out and found it has a plug that goes inyo the top of it. The new intercooler doesnt have anywhere to fix this plug to. Does actually need to stay attacthed and whats it for. And if anybody has a fitting plan for a toyosport intercooler i would b very greatful cheers.
 Andy
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Front mount intercoolers
« Reply #1 on: 17 November 2012, 16:17 »
May it be the MAP sensor plug?
Offline rio_gti
« Reply #2 on: 17 November 2012, 16:44 »
Yep map sensor it is needed unless you get it mapped out by a tuner, or you need one of these drone forge
Offline Prawny
  • R-tech power!!!
« Reply #3 on: 17 November 2012, 17:15 »
no no no no no no no.
Don't make silly comments dude.
You can't just 'map out' the map sensor.
Offline scarr89
« Reply #4 on: 17 November 2012, 17:58 »
Mapping hell!!!
Map used to often. This thread has lost all meaning to me!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 17 November 2012, 18:54 »
Map map map
Offline rio_gti
« Reply #6 on: 17 November 2012, 19:13 »
 :embarrassed:
I'm gonna go over there and sit down quietly
Offline smally11981
« Reply #7 on: 17 November 2012, 19:50 »
Offline rio_gti
« Reply #8 on: 18 November 2012, 01:25 »
My bad mate, what I pictured is needed, but I'm sure I see some of the eBay kits that have the map sensor pipe with it. What size ic pipe work you running??
You can buy a flange but will have to get it welded to the pipe you have (about £18 from USA)
Offline cooki
  • 1.8T AUM
« Reply #9 on: 18 November 2012, 09:40 »
Awsome gti sell the little flanges aswell mate for £22 im just in the middle of ordering one for my toyosport front mount.
Also what engine code is your golf?if its an AUM you will need a 7mm alloy take off for the n75 valve welding on by the dv take off.
I also need this doin.proving difficult finding some1 local with an alloy welder thogh.
Mite just get rid and scrap the intercooler idea.
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
