Author Topic: Normal oil temp  (Read 941 times)
Offline CJA321
Normal oil temp
« on: 15 November 2012, 00:55 »
As above, whats yours? Im having a couple issues with oil temps and coolant temps acting erracticly atm.
Wondering whats your normal oil temp?
Mines sitting at 92ish C at idle.
And anything from 96-104 driving like a loon. Seems very high to me. So whats normal? Thanks in advance
« Last Edit: 15 November 2012, 09:16 by Rhyso »
Offline rockmonkey69
Re: Nornal oil temp
« Reply #1 on: 15 November 2012, 01:44 »
If driven hard I see temps of around 120 Celsius, far too hot for my liking, I am looking at an external oil cooler, the factory oil/water cooler is only suited for some fast road driving. For trackdays you ideally want an uprated oil cooler, it will help with the degradation of your engine's oil and keep it in the temperature range which it lubricates best at.
Re: Nornal oil temp
« Reply #2 on: 15 November 2012, 08:56 »
That is about right tbh, I would not worry.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Normal oil temp
« Reply #3 on: 15 November 2012, 12:28 »
Don't forget your oil and water run around the same temp due to the heat exchanger
