Author Topic: oil pressure  (Read 1512 times)
Offline patryk92
oil pressure
« on: 14 November 2012, 22:36 »
after rebuilding the engine i dont seem to have oil coming up to the top of the engine. is it possible that i have fitted oil cooler upside down as it looks the same from outside and its not letting the oil to come up ? engine is abf
Re: oil pressure
« Reply #1 on: 15 November 2012, 08:52 »
I would say your have a bigger problem, my guess would be an assembly issue.
(Head gasket blocking an oilway maybe)
Offline leigh_harty
  • Audi AGU
Re: oil pressure
« Reply #2 on: 15 November 2012, 09:22 »
Have you connected the 'spindle thingy' that goes into the pump?
On my vr theirs an Allen key style spindle that goes up into the block and into the oil pump (what turns the pump)
That or their is a block somewhere. Take out the oil pressure switch and crank it over to see of anything comes out
Dont lose your dinosaur!
Offline patryk92
Re: oil pressure
« Reply #3 on: 15 November 2012, 21:16 »
ok so today i checked the oil cooler with the one fitted onto the old engine and its fitted the correct way.i started up the engine and took oil filler cap off and there is no oil splashing about at all. the head gasket was fitted the right way around, but would it be possible to fit wrong one ? the head set was for 2.0 16v abf, metal type gasket, could the gasket be wrong ? i dont really fancy taking  the head off just to find out that its ok. i was planing to check oil pressure at the switch with a guage. what pressure should it be when idling ?
Offline leigh_harty
  • Audi AGU
Re: oil pressure
« Reply #4 on: 15 November 2012, 22:52 »
If your capable of rebuilding an engine I think you would notice if the HG was wrong or on wrong. Oil & water galleries wouldn't line up. Nor the headbolts presumably?
Just take out the switch and see if anything squirts out, no dash warning?
Re: oil pressure
« Reply #5 on: 16 November 2012, 12:02 »
Did you use a new oil pump ?
Well worth gettin an oil pressure guage fitted and see what you pressures your getting
