Author Topic: Temp gauge  (Read 844 times)
Offline navmk4gti
Temp gauge
« on: 14 November 2012, 15:30 »
The temp gauge on my v6 4 motion has started rises slowly when im parked up to about 95 then the fans kick in and it drops back to 90 and is fine.
When im driving it is siting at 90 and drives fine. Could it be temp sender thermostat im not sure cus the fan is kicking in and then it rises for about 3 seconds then drops and fans cut off. i never heard fan kicking in if temp sender  :cry: :undecided:
Offline topher
  • Administrator
  • fully functioning
Re: Temp gauge
« Reply #1 on: 14 November 2012, 15:38 »
the fans aren't triggered until the coolant is at 95.. but it should still look like 90 on the gauge. If you watch with vagcom the needle can be glued to 90 when the readings are 80-100 degrees!
I'll take a look saturday for you
Offline navmk4gti
Re: Temp gauge
« Reply #2 on: 14 November 2012, 15:41 »
Thanks chris.  what U think it is? Is it ok to drive an stuff tho?
Offline topher
  • Administrator
  • fully functioning
Re: Temp gauge
« Reply #3 on: 14 November 2012, 16:19 »
doesn't sound like its overheating, could be a fan issue or it could just be you being paranoid! :tongue:
Offline navmk4gti
Re: Temp gauge
« Reply #4 on: 14 November 2012, 16:25 »
Hahah na aint being para. Iv made video of it. Good to know fan is working :grin:
Ill post up video when i get home. I need go manchester tomorow thas the prob :cry:
Yh it was fine all dis tym. Just starting today. Fookin brickin it just got the bloody thing :laugh:
I need get on vagcom. Ill do that today let u know any fault codes
