Author Topic: Water in spare wheel area???  (Read 1149 times)
Offline Live in Hope
« on: 13 November 2012, 20:44 »
Anyone had this problem and know where the water is getting in? car is not used much and is parked on a slight higher than rear if that makes a difference? all carpets in car feel dry.
Any help guys would be appreciated!
Offline dom
  • Back in a Mk4
Re: Water in spare wheel area???
« Reply #1 on: 13 November 2012, 20:57 »
Does your rear washer work?
« Reply #2 on: 13 November 2012, 21:08 »
think so but will check tomorrow, is this a common thing to happen?
Offline james18t
« Reply #3 on: 13 November 2012, 22:22 »
I noticed a pool of water in the little compartment where you change your rear bulbs. Have a look in there because it may have overflowed into your spare wheel compartment. If it has there's a big round rubber bung at the bottom. If you push it out it'll fall out the bottom of the car behind the wheel and the water will drain out, then just push it back in.
Offline GTi_James
« Reply #4 on: 14 November 2012, 08:59 »
and it would be worth while clearing out your rear drainpipes, i cut the crimp out so theres more freedom for water to drain out
« Reply #5 on: 17 November 2012, 08:57 »
Rear washer defo works ok, will check drain pipes later today.
Offline mar_k
« Reply #6 on: 17 November 2012, 11:41 »
there is a vent behind the bumper, the rubber seal perishs over time which allows water to enter the boot. its worth taking a look at the vent seals
« Reply #7 on: 18 November 2012, 13:41 »
Just checked spare wheel well and its nice and dry but i have not driven car this week but it is still misting up so checked foot wells all ok but under rear seat drivers side (2 door model) it very wet? where would water be coming from?
