Author Topic: Camber shims  (Read 4211 times)
Offline 67buggers
Camber shims
« on: 13 November 2012, 14:35 »
Right im gearing up to fitting my camber shims but the instructions for them are useless! My shims are double skinned so do i remove sections from both skins? Also when i decide how much tow and camber i want do i remove sections for each number on the dial, for example if i go with 20/20 do i line up the outer 20 and snip the sections out then line up the inner 20 and snip out those sections?....... Im not explaining this well!
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline tweed
Re: Camber shims
« Reply #1 on: 13 November 2012, 16:01 »
Do not do 20/20. Get your rear toe measured and see what it is and where it needs to be than adjust the shims to suit.
Then leave it together put it on vw hub bolt pattern and cut out what you don't need. Use a stanly knife.
I would get my toe measured but I can't lol
Ill get mine out tonight and tell you what I'm going to do.
Offline 67buggers
Re: Camber shims
« Reply #2 on: 13 November 2012, 18:20 »
Ok cool. When i cut out what i dont need do i have to cut out bits for the camber then the tow ?
Offline tweed
Re: Camber shims
« Reply #3 on: 13 November 2012, 18:26 »
You sound like your confused  :laugh:
When you planning on doing this? I will take some pics later or Saturday as I need to do mine. And ill be able to get mine bang on with the wheel off.
Offline tweed
Re: Camber shims
« Reply #4 on: 13 November 2012, 20:24 »
Camber shim settings!
Driver side I'm having 17-17
Passenger side I'm having 23-23
As you can see I put the numbers I want to the arrow on the chart, then with the chart markings I will cut out the tabs with a sharp stanly knife. Take your time when cutting them out. Cut down the sides then repeatedly bend the tab so it snaps.
When fit them, job done!
Offline 67buggers
Re: Camber shims
« Reply #5 on: 13 November 2012, 21:23 »
Confused ain't the word but think your pics have sorted me cheers dude........ How come your having different settings?
Offline tweed
Re: Camber shims
« Reply #6 on: 13 November 2012, 21:30 »
Because 20-20 is -1.5 camber and 0 toe, when the rear beam is at standard height. So when you lower the beam it puts it out to more like -1.2 camber and 0.3 toe in each side.
I didn't think of this at the time and made the error.
Offline 67buggers
Re: Camber shims
« Reply #7 on: 13 November 2012, 21:41 »
So does 17 and 23 sort the tow and give 1.5 camber? I didnt realise the shims moved! Lol hence my confusion!!
Offline tweed
Re: Camber shims
« Reply #8 on: 13 November 2012, 22:14 »
Yes mate that's if your low though.
Offline 67buggers
Re: Camber shims
« Reply #9 on: 14 November 2012, 06:14 »
ATM the rear aint that low maybe 40mm, plan is to get some camber on and roll the archs to let me go lower
