Author Topic: Whistling from engine bay ???  (Read 1373 times)
Offline lagrynfaya
« on: 12 November 2012, 19:02 »
I got a whistling noise coming from my engine. it gets a bit louder when i accelerate put nothing major. this started to happen when i change my power steering belt. Personally I think its the alternator but I will like some advice from other MK3 users  :smiley:
Offline itavaltalainen
Re: Whistling from engine bay ???
« Reply #1 on: 12 November 2012, 19:22 »
could be the p/s belt being too tight then.
Offline DCmk3
« Reply #2 on: 12 November 2012, 20:21 »
Over-tensioned belt or worn pulleys.
2014 Mk7 GTI - Littco L500
Offline tweed
« Reply #3 on: 12 November 2012, 20:25 »
I'm with the above
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 12 November 2012, 20:43 »
Vacuum hose leak
Water pump bearing
Power steering pump
Alternator
Air-Con compressor
Any of these could could a whistling noise with excessive wear.
Offline Len
« Reply #5 on: 12 November 2012, 20:54 »
Check that first as they shouldnt be really tight! You should still be able to move the belt 5mm at least with your finger.
www.sas.org.uk
www.the-ace.org.uk
Offline lagrynfaya
« Reply #6 on: 17 November 2012, 20:41 »
Thanx guys will have a look at all that when i do my gearbox. Will keep you up to date :wink:
