Author Topic: PD 150 problem# UPDATE#  (Read 9704 times)
Offline PATEMANUK
« on: 10 November 2012, 19:13 »
Hi guys for some reason my PD 150 cuts out when on a 20 min drive when it happenes it want start straigth away but leave it for abot 5 mins then it will start and be fine iv done oil change fuel fillter change and a air filter change and i also put it on my mate vcom and cam back with no faults.some people say it could be the cranksharft sensor or the egr valve any ideas thanks
« Last Edit: 25 November 2012, 11:36 by PATEMANUK »
Offline EsSeX dAn
Re: PD 150 problem
« Reply #1 on: 11 November 2012, 02:46 »
does it get hot atall? im thinking it couls be low/no water. there should be a warning pop up when this happens unless theres a faulty sensor
i think i love you.....
Offline PATEMANUK
Re: PD 150 problem
« Reply #2 on: 11 November 2012, 08:47 »
No mate get up temp ok and the heating all nice and hot  :smiley:
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: PD 150 problem
« Reply #3 on: 11 November 2012, 11:46 »
Doubt it has anything to do with your EGR. Something do to with fuelling? Pump on way out?
Offline Rhyso
Re: PD 150 problem
« Reply #4 on: 11 November 2012, 17:38 »
Fuel pump relay  :undecided:
Offline scarr89
Re: PD 150 problem
« Reply #5 on: 11 November 2012, 18:01 »
Intermittent fuel pump relay issues, hence it didn't show up as an error?
Perhaps just all your fuses and relays/wiring etc?  :undecided:
Offline Rhyso
Re: PD 150 problem
« Reply #6 on: 11 November 2012, 18:03 »
Re reading your original post it could be the sensor you mentioned. I assume you wait for the car to cool down a little before it will attempt to start?
Offline PATEMANUK
Re: PD 150 problem
« Reply #7 on: 11 November 2012, 19:28 »
hi yes i wait for car to cool down takes a couple of minutes then starts again and drives fine ive fitted a crank sensor today as a few people suggested this could be the issue sometimes it doesnt show on the diagnostics
Offline Rhyso
Re: PD 150 problem
« Reply #8 on: 11 November 2012, 19:30 »
Fingers crossed that will fix it for you then  :smiley:
Offline PATEMANUK
Re: PD 150 problem
« Reply #9 on: 11 November 2012, 19:44 »
my fingers are mate lol they say its a common fault  i will look at the relay and the fuses for the fuel pump  in the morning thanks you guys  :smiley: as try to find the fault is doing my head in  :sad
« Last Edit: 11 November 2012, 19:46 by PATEMANUK »
