Author Topic: HELP URGENTLY!!!!!!!!! tip  (Read 1155 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 10 November 2012, 14:34 »
ok fitting a tip onto the turbo and i have got it on,but i have put a jubalie clip on and when i tighten it up the hose keeps coming off arghhhhhhh HELP
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
Re: HELP URGENTLY!!!!!!!!! tip
« Reply #1 on: 10 November 2012, 14:43 »
Strange :S Sure its the right fitment? How tight is it to put on? shouldn't just be sliding off when you tighten it!
Try holding it on with one hand and tighten with the other, sorry to be unhelpful incase you've tried that, or get someone else to push it on tightly whilst you tighten
Mk4 Gti - Gone but not forgotten!
Offline (shakey)
« Reply #2 on: 10 November 2012, 14:54 »
tip goes on ok but cant get the clip to sit right the the hose not sure if the jubalie clip is to big ?
Offline Xtrhardcore
« Reply #3 on: 10 November 2012, 15:00 »
Try a smaller jubilee clip first, might make it sit better and tighten easier
Offline (shakey)
« Reply #4 on: 10 November 2012, 18:30 »
is a jubilee essential where the hose meets the turbo as all it does is suck air not blow it out?
Offline rfn_hodgson
« Reply #5 on: 12 November 2012, 08:54 »
i had this problem buddy when fitting mine i ended up getting a thiner jubilee clip.... and i would have one on as what happens if it comes loose and your sucking in dirty air and not to mention water on wet days :)
good luck with it though mate took me a fair few hours to do the job start to finish lol
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Dalo Harkin
« Reply #6 on: 12 November 2012, 08:58 »
Yeah you do need it on mate,
whats probably happening is when you are tightening the jubilee the ratchet part (that you are turning is hitting the housing)
as the others have said you do need a fairly small and thin jubilee on there there isnt much for it to clamp onto because you cant push the jubilee in too far or you cant get to the ratchet part to tighten it as its in a lip
Offline (shakey)
« Reply #7 on: 12 November 2012, 16:16 »
yeah its a bloody night mare took me couple of hours and still not got a proper jubilee yet will deffo have to get one tho.
