Golf mk4
Wazzzer
what wheel bolt lenth do i need to fit 5mm forge spacers?
Topic: what wheel bolt lenth do i need to fit 5mm forge spacers? (Read 2001 times)
Neg-1989
1.8t agu stag 1map forge v008 www.derbydubs.co.uk
09 November 2012, 20:21 »
just won four 5mm forge wheel spacers off ebay for £12.24 inc post so what wheel bolt lenth do a need to fit these lads? i could go crack one off and see how long it is and add 5mm and order some but that means going out in the cold! haha thanks boys
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: what wheel bolt lenth do i need to fit 5mm forge spacers?
09 November 2012, 20:26 »
5mm is fine with standard length bolts
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
Steve_PD
Serious forum addict
Cruising around in a Land Cruiser
09 November 2012, 20:28 »
32mm but will get away with buying 35mm
rockmonkey69
09 November 2012, 20:38 »
Standard thread length is 27mm so 32mm would be ideal as steve_pd said
dom
10k hero
Back in a Mk4
09 November 2012, 20:47 »
I ran 5mm spacers with standard bolts
shaft69
09 November 2012, 21:09 »
I've 6mm spacers and standard bolt Deffo not long enough.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
rockmonkey69
Reply #6 on:
09 November 2012, 21:28 »
I suppose it's down to each individual, I mean you don't
have
to.
It's just if you don't then you run the risk, if you do then you sleep easier.
Steve_PD
Reply #7 on:
09 November 2012, 21:44 »
I ran 5mm spacers with and without longer bolts and with out they only screwed in 3 threads or 4.5mm
Deffo with longer bolts!
rockmonkey69
Reply #8 on:
09 November 2012, 22:01 »
If that was me, it would have a very profound effect on how I would drive - W would never get out of 1st gear
Definitely get longer wheel bolts, it's not alot of money for what is an integral part.
Xtrhardcore
Here all the time
Mk3 Gti 2.0 8v MoreDoor
Reply #9 on:
10 November 2012, 11:31 »
Sorry to thread jack - what about 20mm spacers?
Mk4 Gti - Gone but not forgotten!
Golf mk4
Wazzzer
