Author Topic: Should I ..... ?  (Read 2197 times)
Offline Nino
Should I ..... ?
« on: 08 November 2012, 19:12 »
As some of you know (most dont  :grin: ) I have a brand new set of JOMS ready, and I have got my front replacement brand new top mounts and bearings, from TPS, (Thanks whoever it was that recommended them) but I was thinking about replacing the rears too while its all off.
My question is isit worth it? as there around £50 to replace the rears.
Your thoughts please?
Current - MK6 GTi Edition 35
Offline jamie1989
Re: Should I ..... ?
« Reply #1 on: 08 November 2012, 19:38 »
Rears wil be fine mate. I personally wouldnt bother  :smiley:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2 on: 08 November 2012, 20:13 »
The rear top mounts aren't quite the same in the way as the fronts provide some sort of dampening. They just help attach the strut to the car. I wouldn't bother.
Offline cullygti
« Reply #3 on: 08 November 2012, 20:15 »
i changed mine just for my own piece of mind with them being 14 years old  :rolleyes:  but didnt pay £50 thats for sure but as said theres no need really as every component on the golf lasts forever  :grin:
« Last Edit: 08 November 2012, 20:19 by cullygti »
Offline GTi_James
« Reply #4 on: 08 November 2012, 20:21 »
 :grin: i wish that was the case, new clutch, new starter motor, new oil pipes for catch can, new battery, new front grill... :cry:
Offline Nino
« Reply #5 on: 08 November 2012, 20:29 »
Thanks for the dvise guys, I just need time ro fit them now :) Im guessing that I fit them with the coilovers set at the highest setting then measure from the arch to floor to get the measurements correct all round? only thing Im wondering about is how do you get the the adjuster?  :huh:
« Reply #6 on: 08 November 2012, 23:53 »
Just get some from ebay, better to fit new if you can.
Offline Nino
« Reply #7 on: 09 November 2012, 20:58 »
Okie dokie, How do I adjust the coil over once they are fitted? (stupid question)
Offline AD1.8T
« Reply #8 on: 09 November 2012, 22:05 »
I found the best way was to use a pressure washer to blast the adjuster round that way you dont have to take the wheels off to get to them ...... :whistle:
Offline Nino
« Reply #9 on: 10 November 2012, 07:51 »
Damit! i dont have one of thous! :( whats is the correct way of doing it?
