Golf mk4
Wazzzer
Drivers Door Problem
Topic: Drivers Door Problem (Read 1140 times)
hotdogsmale
Here all the time
You just cant go wrong with a golf!
07 November 2012, 19:08 »
Hi guys
I am having a problem with my mk4 golf, 5 door drivers door lock. I am able to unlock the drivers door with the key but it will not unlock any other door, the immobliser light stays flashing. Using the passenger lock all works as it should. This is not remote locking. I have found that the lock has become stiff when turning the key in the lock. Anyone had this problem before? Ideas will be much appreciated.
Thank You
Josh
harlemex
Re: Drivers Door Problem
08 November 2012, 17:21 »
the drivers lock is knackered, probably needs a new paddle,. take the handle off and investigate.
hotdogsmale
Here all the time
15 November 2012, 19:17 »
now i am having more problems as i lock the door sometimes it will unlock itself? :/ What do i change
hotdogsmale
Here all the time
03 December 2012, 09:51 »
replaced drivers door lock but now it seems very very sensitive or all the windows come down any ides? cheers
GTi_James
03 December 2012, 11:25 »
wired incorrectly? fuses checked? and have you reset everything? ie put key in lock, turn to unlock and hold, windows down, then release, turn back to lock, release then, back to lock and hold for 8 secs?
navmk4gti
Forum addict
03 December 2012, 12:03 »
Change door module get one for £20-30
Website:
https://www.theonestopledshop.com/
Golf mk4
Wazzzer
