Author Topic: k04-001 forge actuator  (Read 1615 times)
Offline km
« on: 07 November 2012, 15:44 »
ordered a ko3 actuator, the 2 left holes line up. however, the further right one is nowhere near.
is there another bracket for k04-001 or will this have to do?
the rod seems to function fine so... help.
« Last Edit: 07 November 2012, 22:47 by km »
Offline rio_gti
Re: k04-001 forge actuator
« Reply #1 on: 07 November 2012, 15:53 »
drill a new hole??
Offline DunnDeal12
  • Limited
« Reply #2 on: 07 November 2012, 15:56 »
that doesn't even look like a 1.8t forge actuator in the second pic.
Offline km
« Reply #3 on: 07 November 2012, 23:13 »
drill a new hole??
the turbo housing is at an angle with the bracket. but i'd rather the correct bracket if forge will supply it.
i've taken photos to compare the 2. appreciate it if someone with a k03 actuator could confirm mine's correct/wrong. or even better if you have one on your k04-001 :)
Offline Prawny
  • R-tech power!!!
« Reply #4 on: 07 November 2012, 23:21 »
you have the new style forge actuator, they changed them recently.
I'd redrill the bracket, or contact forge and say it's wrong, they have a few different ones I understand.
Offline km
« Reply #5 on: 07 November 2012, 23:27 »
a few? this is gonna be a challenge to get the right one. i'll give them a ring in the morning. thanks prawny :afro:
Offline littco
« Reply #6 on: 08 November 2012, 10:55 »
Re drill the bracket. Seen this before as long as the rod comes out of the actuator square qhen fitted it'll be fine. These have been known to melt by the way.
Offline rio_gti
« Reply #7 on: 08 November 2012, 10:56 »
what melts?  :shocked:
Offline km
« Reply #8 on: 08 November 2012, 11:52 »
 :shocked:
contacted them this morning and they're sending another bracket :cool:
