Author Topic: large spring found????  (Read 2894 times)
Offline cooki
  • 1.8T AUM
« on: 07 November 2012, 09:52 »
Well ive found a large spring on the floof under my seat this morning with a cuple of bits of plastic that had snapped. Spring has a hook fitting on each end.
Is it something to do with the tilt of the seat or something.guesing the fixing point for it has snapped and thats what the plastic is????
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: large spring found????
« Reply #1 on: 07 November 2012, 10:44 »
Had the same mate, doesn't seem to affect the seat operation so it went in the glove box lol
Offline cooki
  • 1.8T AUM
« Reply #2 on: 07 November 2012, 11:33 »
Fair enough mate. Sounds like a plan lol.
Havnt tried the seat yet as im in work and found it this morning on the way in.
Offline sveed1.8T
« Reply #3 on: 07 November 2012, 12:47 »
Look underneath the opposing seat to see how it is meant to fit. But as Wez said, it makes bugger all difference to the workings of the seat :smiley:
« Reply #4 on: 07 November 2012, 14:03 »
It is to do with the height adjustment, mine broke on the Skoda but it all seemed to work without it all ok.
Offline rio_gti
« Reply #5 on: 07 November 2012, 15:39 »
So what we're saying is remove it as its not needed?? Weight reduction  :laugh:
Offline sveed1.8T
« Reply #6 on: 07 November 2012, 16:08 »
Whilst you're at it, remove the passenger seats, passenger airbag and anything on the passenger side as you won't need it!! :laugh:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #7 on: 07 November 2012, 17:25 »
Happened to me as well!  :laugh:
Been in the gloves box for nearly 2 years! :lipsrsealed:
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #8 on: 07 November 2012, 17:58 »
Mine is also missing from drivers seat, I tried to fit it when replaced the foam base part but couldn't figure out how it fits at the rear part, as others say doesn't seem to affect any operation of the seat I think it is supposed to assist the height adjustment ie make the lever easier to operate? or something like that. Found this though so might have another go at it sometime...
Remove seat.
Note
    Before removal, seat must be moved to highest position to reduce height adjustment spring tension as much as possible.
Remove screw 2 and unclip trim 1.
Unclip two covers 11, unscrew two bolts 12 and remove adjustment lever 13.
Remove screw 17 and unclip trim 14.
Carefully detach tensioning springs 2.
Unscrew three bolts arrows (10 Nm) and pull seat height adjustment element 1 out of seat frame.
Source: http://elsaweb.spaghetticoder.org/doc/V.en-GB.K05510989/27585173/3
« Last Edit: 07 November 2012, 18:03 by Golf_GT_TDI »
Offline cooki
  • 1.8T AUM
« Reply #9 on: 07 November 2012, 22:37 »
Thanks for all your input guys. Think the best and most commonly used place to store it is the glove box :) )
