Author Topic: Gearbox Problem  (Read 1578 times)
Offline ibmike
Gearbox Problem
« on: 15 July 2005, 20:56 »
Hi everyone just found this great forum and learnt alot already but i have a question regarding my gearbox
First off car details
MK3 2.0 (Agg) GTi 8v Anniversary
Problem is since i have had the car about a year it goes into all gears fine without a hitch drives good
but it jumps out of reverse is this a common fault or does anyone know what could be wrong ???
I am a mechanic but work for fords if these boxes are easy to fix i may have a go but would prefere to get it done by someone who knows the boxes
Thanks
I am in the chester area if anyone knows anywhere to go
Offline GTI EDITION (aka LTD)
Re: Gearbox Problem
« Reply #1 on: 16 July 2005, 13:52 »
It sounds like it's in need a strip down but I wouldn't advise you attempting it unless you have access to the special VW tools required to strip and rebuild it and all the relevent setting up data required( I rebuilt VW gearboxes in the past and they are not as straight forward as some other makes :wink:
I think in the long run you maybe better off getting a REPUTABLE gearbox specialist to do it as you'll get it turned around a lot quicker and also get it guaranteed for 12months at least  :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline perd999
Re: Gearbox Problem
« Reply #2 on: 16 July 2005, 18:15 »
complete common failure, if i was you id just change the gearbox, i got mine done for 175 including fitting, i also have been told teh mk2 16v box fits the mk3 8 valve?? dont quote me on it though
Offline ibmike
Re: Gearbox Problem
« Reply #3 on: 17 July 2005, 14:06 »
The only thing is i have heard the ratios are all different i really want the car as standard (for now)
Anyone recommend anywhere to get it done ???
Got a quote from a local guy he said £300 for the reverse or £500 for complete overhaul
A bit on the expnsive side i think ???
Anyway any where local to chester or if you know somewhere i can get a re-con box please let me know
Thanks
Offline the beast
Re: Gearbox Problem
« Reply #4 on: 31 August 2005, 20:30 »
:sad: so it's no just me :cool: mine dose that on a  Mk3 gti 8v think it's a worn reverse gear?   :huh: what to do  :rolleyes: change box  when i find one to fit  that 020 box  :angry: anyone got a good one for sale at the right price please :kiss: help
