Author Topic: help stuck rear brakes.  (Read 862 times)
Offline Big Tone
« on: 04 November 2012, 13:30 »
Nsh!t quite a golf mk 4 but a seat Leon so more or Less the Same car.
My mates rear piston has siezed. It was stuck far out. Tried to re wind it with the rewind tool. Solid. My mate tried again later and the piston has spun round easily and come out of the cylinder. Help.
It is currently claimped in place as not to let the brake fluid cone out!
What to do,?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline mike1990
Re: help stuck rear brakes.
« Reply #1 on: 04 November 2012, 13:31 »
You'll need a new caliper mate
Offline Big Tone
« Reply #2 on: 04 November 2012, 13:34 »
Can I do this today. On the drive?. Not bled brakes before. Or can I just bleed the one caliper?
Offline mike1990
« Reply #3 on: 04 November 2012, 13:37 »
You can do it on the drive, my dad's car has the same problem. The caliper piston has come out too much, pressing the pads against the disc and making a awful noise when driving. Just a new caliper needs fitting, bleeding and maybe a change of pads if they have been worn too much.
Offline Dalo Harkin
« Reply #4 on: 05 November 2012, 13:01 »
If the pads were worn enough then the caliper piston will come out, or if you wind it the wrong way  :whistle:
It should go back in with some force, just make sure the seal is ok and and that you bleed at the very least that one caliper, preferably all of them
Offline bbewekim
« Reply #5 on: 06 November 2012, 10:48 »
VW do a brake caliper service kit for about £20 inc vat. As there are no mechanical parts in the caliper you just need to replace the rubber seals its a very easy job and you get seals for both calipers in one box. Takes about a hour to do give or take, £20 vs a new caliper is win win, especially if you were considering getting one from a scrappy which could have the same problem a few miles down the road.
