Author Topic: Drive Shaft popped out (SORTED) :)  (Read 3372 times)
Offline pickles
  • Next!!!
« on: 03 November 2012, 20:10 »
one thing after another alright lol, can the drive shaft pop out if not supported correctly, its took a couple of dunts and looks rather loose, also got grease coming out the boot, gna have a better look tomoro
« Last Edit: 04 November 2012, 20:13 by pickles »
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Toby
  • Car - less
Re: Drive Shaft popped out
« Reply #1 on: 03 November 2012, 20:11 »
I had 3 in 2 months  :laugh:
Currently down under
Offline pickles
  • Next!!!
« Reply #2 on: 03 November 2012, 20:18 »
ouch, meant to add i was changing the shocks at the time and thought i had them supported properly.(obv not) kinda just been hanging there, any chance itl just pop bk in
Mapped
Nearly S3 time  :)
Offline cullygti
« Reply #3 on: 03 November 2012, 20:19 »
yep has happened to me to luckily its an easy fix  :wink:
Offline pickles
  • Next!!!
« Reply #4 on: 03 November 2012, 20:21 »
just what i was wanting to hear, is it just a matter of taking the flange bolts out and refitting the joint to whatever it is its fixed too then bolting it bk up lol
Mapped
Nearly S3 time  :)
Offline cullygti
« Reply #5 on: 03 November 2012, 20:23 »
yes mate
mine popped off completely so had to order new spacer thingys  :grin: from vw only a few quid but all sorted  :cool:
Offline pickles
  • Next!!!
« Reply #6 on: 03 November 2012, 20:25 »
yes mate
ideal  :laugh: be up at th crack of dawn too do it :)
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
« Reply #7 on: 03 November 2012, 20:52 »
any1 know a way to crack the bolts easily without the joint turning
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
« Reply #8 on: 03 November 2012, 21:13 »
right, after a bit of research i think the circlip holding the axle into the tripple roller assembly has came off and the shaft is lying loose in the boot.
does this sound about right
Mapped
Nearly S3 time  :)
Offline Steve_PD
« Reply #9 on: 03 November 2012, 21:18 »
Yes that sounds right!
And to undo the bolts put 2 wheel bolts back in the hub and use a breaker bar to hold the hub while you crack off the bolts. Will need an extra pair of hands though.
