Author Topic: What injectors and fueling  (Read 1920 times)
Offline Scott-R
  • GoT BoosT!
« on: 31 October 2012, 20:43 »
For my setup "in sig" . Looking to make good power and hopefully take car to r-tech see if they can sort my map out.
Golf GTI ... What else would you have?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: What injectors and fueling
« Reply #1 on: 31 October 2012, 21:02 »
S3/TT injectors and fuel pump needed IMO
Offline Scott-R
  • GoT BoosT!
« Reply #2 on: 05 November 2012, 21:45 »
does anyone have this sort of setup with uprated injectors? any major risks with going this far?
Offline Reesy23
« Reply #3 on: 06 November 2012, 10:00 »
I have a very similar set up and run S3/TT injectors and a 4far fpr.
Both of which are about to go up for sale if you are interested  :whistle:
Offline Prawny
  • R-tech power!!!
« Reply #4 on: 06 November 2012, 12:50 »
it's an S3/TT/LCR turbo, so run S3/TT/LCR injectors my man.
You'll also need the MAf from the above too.
Offline Chris#101
« Reply #5 on: 06 November 2012, 17:09 »
What K04 are you runinng reesy? got a project thread? i think im gonna k04-02* next. have you uprated your rods?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Reesy23
« Reply #6 on: 07 November 2012, 08:52 »
I do have a project thread but it's on Audi-sport.net.
My car is running the following:
K04-022? (Non EGT)
3" Downpipe and Decat
XS V2 Mani
2.75" Scorpion Decat back
Large port inlet mani
Large port Head
80mm TIP
S2000 Cone Filter
Welly cooler and 63mm pipes
Forged Rods
N/A Inlet Cam
Variable maps.
Offline turbokid23
« Reply #7 on: 07 November 2012, 11:09 »
Pop a link up then
Offline rio_gti
« Reply #8 on: 07 November 2012, 13:02 »
K04-022? (Non EGT)
XS V2 Mani
Large port Head
80mm TIP
S2000 Cone Filter
Forged Rods
N/A Inlet Cam
Variable maps.
What power u gettin from that little lot then?!!
Offline Reesy23
« Reply #9 on: 07 November 2012, 13:12 »
Turbo is maxed out at 290bhp as it has done a few miles.
It was making that before the large port head and inlet mani went on though, so it would be seeing closer to 300 I think, possibly just over..
