Author Topic: That diesel ticking noise when idling  (Read 2100 times)
Offline Cerialkarpins
« on: 28 October 2012, 14:04 »
ello, i kno there is a thread for this but still
all of you that have noticed this, do u run your car on v-power?
because im sure mine only started to make the noise after i topped up the tank with it. previously topped up with tescos 99 stuff didnt notice it. although i did have the cambelt changed last month so i'll probs be popping it back just to get it checked over. but yeh just thought id ask it.
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
Re: That diesel ticking noise when idling
« Reply #1 on: 29 October 2012, 08:20 »
More likely to be the cambelt tensioner than v-power - fairly common problem, but normally associated with worn tensioners - did they replace the belt only? How about the water pump?
« Reply #2 on: 29 October 2012, 18:39 »
They did the waterpump aswell but I have no idea about the tensiometer. Best check the invoice :p. Cheers for the heads up on them
Offline Adam
« Reply #3 on: 29 October 2012, 19:22 »
Could be the HPFP follower getting abused by the lobe.
Down Hill From Here.
Offline MS1COYS
  • Alfie 'H' 10-09-11
« Reply #4 on: 29 October 2012, 20:35 »
Just FYI my Gti's fuel injectors tick quite a bit louder on V-Power than say Techron or Ultimate, so it could be that.
I remember when I first bought the car, I thought something was f**ked with it, because it sounded like a GTD!
292bhp / 287lbft
« Reply #5 on: 31 October 2012, 18:51 »
Ello yeh had tensionsers changed I think it  might just be the noise the car makes just never really noticed it before.cheers for all the info guys.
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 31 October 2012, 20:26 »
and they're only £30 from the dealer so probably worth changing anyway if it's never been done. i've always found the FSI engines to be very ticky though
